Manning’s n Goes Vertical
Written by Chris Goodell | November 30, 2026
Kleinschmidt Associates
Copyright © 2026
HEC-RAS 2D Has Flow Roughness Factors!
Every once in a while, HEC sneaks something into RAS that makes me stop and say, “Wait…we can do that now?”
That was my reaction when I discovered Flow Roughness Factors for 2D Flow Areas. They’ve actually been in HEC-RAS since Version 6.6, quietly sitting there while I apparently wasn’t paying attention.
This isn’t some insignificant little enhancement. For the first time, we can change Manning’s n in a 2D Flow Area as flow changes. That’s huge. Sure, it was mentioned in the Release Notes, and we should always read the release notes! But for something this big, I was expecting confetti, a marching band, maybe Gary Brunner cutting a ribbon.
Instead, here we are at Version 7.0.2, and I’m just now finding it. So, of course, the first thing I did was pull out my trusty flume model and see how it actually works. As one of my recent course attendees so perfectly put it: “It’s flume time!”
Why am I so excited about flow roughness factors? Because since RAS introduced 2D modeling with Version 5.0, we’ve had to live with a significant limitation: for 2D models, we couldn’t vary Manning’s n with flow or stage during a simulation. And, as we all (should) know, Manning’s n actually changes with depth.
At lower water levels, the roughness elements along the bed and banks are large relative to the depth of flow. The water column becomes increasingly influenced by those roughness elements, and the effective Manning’s n tends to increase. As depth increases, the relative influence of those same roughness elements decreases, and Manning’s n will often approach a more stable value.  There are other factors at play too. Notably vegetation can influence n values differently at different depths.
At very shallow depths, particularly when the flow depth begins to approach the scale of the roughness elements themselves, the effective n value can increase. A lot.
Figure 1. Typical Manning’s n value-depth relationship.
So, as of Version 6.6, we finally have the ability to vary our n values with stage.
Well…not exactly.  We can vary them with flow, not stage. Not ideal, but I can work with that.
Now, before we all rush out and start adding Flow Roughness Factors to every 2D model, let me be clear: most models probably don’t need them. For a typical flood model, dam breach model, or bridge/culvert design model, we’re usually interested in a particular range of high-flow conditions. A single Manning’s n representative of those conditions is generally all we need.
Where this gets interesting is when the entire range of flows matters. Maybe your simulation starts at low flow, rises to flood stage, and then drops back down, and you care about the hydraulics throughout the entire event. Or maybe you want the same model to work well for both low-flow and flood conditions without creating separate geometries. That’s where Flow Roughness Factors really start to earn their keep, particularly when you’re trying to calibrate the model across multiple flow conditions.
How Flow Roughness Factors Work
If you’ve ever used Flow Roughness Factors in a 1D HEC-RAS model, the concept is very similar. Rather than specifying a completely different Manning’s n for different flows, you define a relationship between flow and a roughness factor that is applied to the underlying Manning’s n values.
For example, if you want your n values to be 20% higher within a particular flow range, you assign a Flow Roughness Factor of 1.2. A base n value of 0.030 would therefore become:
0.030 × 1.2 = 0.036
Likewise, if you want the n values to be 20% lower, you assign a factor of 0.8:
0.030 × 0.8 = 0.024
That gives us a simple way to increase or decrease the relative roughness as flow changes.
Figure 2.  Example flow roughness factor table with continuous changes in roughness factors.
One important thing to keep in mind is that RAS interpolates the roughness factors between the flows entered in the table. So, if you’re trying to create discrete flow ranges where the roughness factor remains constant, you need to structure the table accordingly.
Figure 3.  Example flow roughness factor table with stepped changes in roughness factors.
In 1D models, these flow-roughness relationships can be assigned to individual cross sections or, more commonly, to ranges of cross sections. This has always been a useful way to calibrate a model across the range of flows experienced during an event rather than forcing one Manning’s n value to work equally well everywhere and at every flow.
Now we can do something similar in 2D.
Flow Roughness Factors in 2D Areas
For a 2D Flow Area, Flow Roughness Factors are assigned to Calibration Regions. You may also see these referred to in RAS as 2D Area Manning’s n Regions or Override Regions. Notice the new “+Calib Region” button in Figures 2 and 3.
There is an interesting wrinkle here.
RAS needs a flow associated with each Calibration Region so that it knows which Flow Roughness Factor to pull from the table. But unlike a 1D cross section, a Calibration Region does not necessarily span the entire flow path.
So what flow does RAS use?
RAS determines which cell faces have flow leaving the Calibration Region and sums those outflows. That summed outflow becomes the flow associated with the region and is used to determine the applicable Flow Roughness Factor.
That distinction is important.
If your Calibration Region only covers part of a river, rather than spanning the entire river, the flow being used to look up the roughness factor is not the total river flow. It is the flow leaving that particular Calibration Region.
Be careful with that one.
Putting It to the Test
Naturally, I wanted to see how this actually worked.
So I pulled out my go-to flume model and adapted it to test 2D Flow Roughness Factors.
The model is about as simple as it gets: a rectangular 2D Flow Area, 100 meters wide and 1,000 meters long, with a very mild longitudinal slope of 0.005%. Nice and flat.
The model uses a structured 5-meter computational mesh with a base Manning’s n of 0.06. A uniform inflow hydrograph is applied at the upstream end, with a normal-depth boundary condition at the downstream end.
For this experiment, I created a Calibration Region about halfway down the flume that covers only the left half of the channel.
Figure 4. Flume model schematic showing calibration region.
I intentionally made the test a little extreme because I wanted the effects of the Flow Roughness Factors to be obvious. The inflow ramps from 0 to 5 cubic meters per second (cms) over approximately 10 hours. Admittedly, that isn’t much flow for a 100-meter-wide channel, but that’s intentional. The flume is extremely flat, and the flow changes slowly, which helps keep things hydraulically simple so I can focus on the effect of changing Manning’s n.
Figure 5.  Inflow hydrograph.
Those relatively low flows resulted in maximum depths of only about 0.5 meter.
During the ramp-up, I paused the hydrograph at several specific flow rates and held the flow steady. That gave the model time to settle toward a relatively steady condition at each target flow before moving on to the next one.
Here is where the Calibration Region geometry becomes important.
Because my Calibration Region only spans half of the flume, I set the flows in the Flow Roughness Factor table to approximately half of the total inflow. In other words, when 2 cms is entering the flume, I would expect roughly 1 cms to be associated with the half-width Calibration Region under reasonably uniform conditions.
Again, the representative flow for the Calibration Region is not necessarily the total flow moving through the model.
To make the effect especially easy to see, I used intentionally exaggerated roughness factors, beginning as high as 4 and eventually dropping to 0.5. For flows between 1 and 1.5 cms, I wanted to return to the base Manning’s n, so I assigned a roughness factor of 1.0 over that range.
Figure 6. Flow roughness factors applied to the flume model.
The Results
And sure enough, the results show a very clear response to the changing roughness factors.
At time 02:40, the flow leaving the calibration region is about 0.5 cms so the Flow Roughness Factor is 2.0. The base flume Manning’s n remains 0.06, while the effective n inside the Calibration Region is 0.12.
Figure 7.  Time 02:40, Flow roughness factor = 2, Flume n value = 0.06, Calibration region n value = 0.12
At time 06:00, the flow leaving the calibration region is 1 cms and the Flow Roughness Factor has dropped to 1.0. The Calibration Region is therefore using the same n value as the rest of the flume: 0.06.
Figure 8. Time 06:00, Flow roughness factor = 1, Flume n value = 0.06, Calibration region n value = 0.06
And by time 08:40, the flow has increased to 2 cms so the Flow Roughness Factor is 0.5, reducing the effective Manning’s n inside the Calibration Region to 0.03.
Figure 9. Time 08:40, Flow roughness factor = 0.5, Flume n value = 0.06, Calibration region n value = 0.03
The resulting velocity patterns make the effect easy to see. Increasing the Flow Roughness Factor slows the water moving through the Calibration Region relative to the rest of the flume. Decreasing it does the opposite.
So, yes. It works.
And it opens up some really interesting possibilities for 2D model calibration.
But There Is a Catch
There is one downside that I found.
As far as I can tell, there isn’t currently an easy way in RAS Mapper to display the actual effective Manning’s n being used during the simulation after the Flow Roughness Factors have been applied.
RAS provides several ways of viewing the underlying or “final” Manning’s n values spatially, but those displayed values do not reflect the Flow Roughness Factors being applied dynamically during the simulation.
That makes troubleshooting and reviewing these adjustments a little less transparent than I would like.
There is, however, a way to peek under the hood.
If you dig into the output HDF file, you can see the Flow Roughness Factors being applied for the mapping output intervals. From there, you can correlate the reported factor with the underlying Manning’s n value to determine the effective n being used at that point in the simulation.
It takes a little more digging than I would prefer, but at least the information is there.
Final Thoughts
For something that showed up rather quietly in the release notes, I think this is a huge addition to HEC-RAS 2D modeling.
Until now, 2D modelers have generally had to calibrate Manning’s n with essentially one set of roughness values across the entire range of simulated flows. But real-world resistance doesn’t necessarily behave that way, particularly when a model spans everything from very shallow flow to much deeper flood conditions.
Flow Roughness Factors give us another lever for representing that behavior and, perhaps more importantly, another tool for calibrating 2D models across a range of flows without forcing one set of Manning’s n values to do all the work.
Just remember that the controlling flow is tied to the outflow from the Calibration Region, not necessarily the total flow in the river.
And maybe someday we’ll get a simple RAS Mapper output showing the effective Manning’s n changing through time.
Until then, I’ll happily take the new feature.
Even if HEC forgot the confetti.
You can read more about this feature in the HEC-RAS 2D User’s Manual.
