Welcome to the RAS Solution › Forums › HEC-RAS Help › What replaced HEC-GeoRAS for terrain processing?
  • #18447
    A Atkinson
    This is an outdated question – but what replaced the HEC-GeoRAS terrain processing process? I remember using the HEC-GeoRAS tools in ArcGIS Pro and haven’t had to use them for a several years now because I haven’t had to process terrains for building models from scratch. But now I am getting to where I need to do that again, but it looks like HEC-GeoRAS is no longer a thing. I know I can go in on RAS Mapper and burn in the bridge lines etc., but what about all the fill sinks etc. steps? How is that usually done now? Thank you!
    #18448
    Chris Goodell
    Yes, RAS Mapper is the replacement. I believe you can still use GeoRAS if you like some of its features, but the normal workflow is to now use RAS Mapper to build your geometry.
    #18449
    Scott Miller
    Short answer: you can use Mapper in HEC-RAS 5.x and 6.x.
    HEC-RAS has had a native GIS for 10 years. Mapper facilitates assembling terrain and terrain modifications and facilitates development of 1D and 2D hydraulic models, cutting cross-sections more cleanly than HEC-GeoRAS ever did for 1D. The HEC-GeoRAS ArcMap extension was only supported through about ArcMap 10.3, and ArcMap itself is no longer supported.
    HEC-RAS 2025 moved from alpha to beta development phases earlier in 2026. At this point I think it’s advisable to look towards where HEC-RAS heading.
    #18450
    A Atkinson
    Thank you!!
