The No-Rise Surprise
UPDATE. HEC has asked that I no longer distribute HEC-RAS 4.2 with 2D Alpha. Their purpose for releasing this alpha version is to get constructive feedback so that they can improve its functionality and efficiency; and to minimize bugs before the offical beta release-not to be critically compared to other established 2D software packages…yet. So far, they have received no comments from anyone I have distributed the software to, which is very disappointing. Please keep your eye out for the official beta release, which is due out early next calendar year some time. You will be very impressed with its capabilities! In the meantime, if you have been given a copy of the alpha version of RAS2D, please take a brief moment and provide some comments and/or suggestions to HEC. User feedback is very important to their product development.
Sorry for any inconvenience. Chris @RASModel
ANOTHER UPDATE. The release of RAS2D beta is now projected to be end of February, 2014. I’ll post updates as I get them. Chris @RASModel
UPDATE #3. RAS2D will now be released as a new feature in HEC-RAS Version 5.0. There will be no official release of RAS2D under version 4.2. The Beta version of HEC-RAS 5.0 is due to be released in the March/April 2014 timeframe.
UPDATE #4. Latest indications are Version 5.0 beta will be released at the end of April, and the full version will be released at the end of the summer.
UPDATE #5 (as of May 11, 2014). Latest indications are Version 5.0 beta will be released in 2 to 3 weeks, putting it at the end of May, early June time frame.
UPDATE #6 (as of May 23, 2014). Version 5.0 beta is out!!! Go get it at http://hecrasmodel.blogspot.com/2014/06/update-to-hec-ras-50-beta.html
I’ve gotten a chance to play around with the alpha version of HEC-RAS 4.2 and check out the program’s new two-dimensional (2D) modeling capabilities. From what I’ve seen this will be a really useful feature! Being the alpha version of RAS2D there are still features in development, and is bound to be a bit “buggy”, but it is definitely worth looking forward to. What is it?
The new build of RAS will allow users to connect 2D flow elements to a 1D river system. You will now be able to model overland areas as dynamic, 2 dimensional grids, rather than level pool storage areas. The figure below shows the 1D and 2D features together in the geometry window. ![]()
How does it work? The 2D mesh and the 1D system are tightly coupled during an unsteady simulation. This means that water surface elevation is calculated at each XS and each grid cell for every timestep, allowing direct feedback at the connections. 2D flow areas can be linked to the 1D system the same way storage areas are. The Figure shown below is a schematic of how the 2D mesh is built, and how RAS routes flow from cell to cell.
Upon creating the 2D mesh, you need to load a digital terrain file (.flt format). Both the pre- and post-processing steps for the 2D flow area are done through RAS Mapper.
Computationally, RAS will allow the user to choose between using 2D Diffusion Wave equations (default), or the full 2D Dynamic Wave equations. Most flood applications should be adequately modeled using the Diffusion Wave equations. What are the advantages?Besides computing in 2-dimensions, the main advantage is the program’s ability to maintain computational robustness while preserving the details of the underlying terrain. Smaller features (i.e. drainage ditches) that run through large cells will be captured in the hydraulic properties of the cell faces. Therefore, these features will be preserved and accounted for both computationally and visually, even though they are smaller than the grid cell size, as demonstrated in the RAS2D output displayed in the figure below. Traditionally, many 2D models require cell size to be consistent with the size of the features to be included. Not the case with RAS2D.
Additional advantages include:
