I’ve been finding that when I run a model that was created with an older version of RAS, I get a message stating that the cross sections have hTab starting values below the cross section invert (see screenshot below). But when I go into the hTab parameters and check, the starting values are NOT lower than the inverts. And even though the warning says that the values will be reset and saved, they never are. I get the same message every time. Anyone else have this issue?
