Welcome to the RAS Solution › Forums › HEC-RAS Help › X-sections Parallel to Road & DS of Bridge
  • #5943
    rlondeen
    I am remapping an area across an existing bridge. The Floodway (dark blue) and floodplain (light blue) were mapped back in the 70s and do not account for the bridge. Some preliminary modeling shows that the 100yr and 500yr do not over-top the road as the maps suggest.
    My question concerns the downstream x-sections. Since the stream takes a sharp turn and runs parallel to the road it makes cutting x-sections difficult. I could either cut them as shown here or create another angle at the road embankment and run each cross-section a foot or so a part.
    any suggestions?
    #9572
    PaoloP
    I guess the flow under the bridge is only in a width as the XS next to the Bridge DS XS depicts.
    In this case I suggest to define the Bridge DS XS with this width and not for the whole bridge.
    Paolo
    #9573
    Thanks Paolo. That makes sense. I will try that.
