Welcome to the RAS Solution Forums HEC-RAS Help x and y co-ordinates of shear stress
Viewing 15 posts - 1 through 15 (of 27 total)
  • #6632
    samreen
    I was trying to create text file for depth, velocity and shear stress. I could export text file for velocity (Node x and Node y velocity) and depth with x and y co-ordinates using HDFView2.14. But I could not figure out the x and y co-ordinates for shear stress. How could I determine x and y co-ordinates for shear stress? Does anyone have an idea about it?
    Thank you
    #10889
    ldguethle
    I don’t have an answer for you, but I would be curious to know how easy it was to generate Velocity x-y components with HDFView. Would you be able to summarize a step-by-step or make a short video?
    Lee
    #10890
    The velocity in x and y is an output option for HEC-RAS under the Output Options so there is nothing to do in HDF.
    #10891
    samreen
    Yes, there is nothing to do in HDF for velocity x and y.
    But shear stress is calculated on the face of cell. Because of this, there is not co-ordinate for shear stress value. I have to plot shear stress in a scatter plot. For that I need (x,y,z) points. z as a shear stress and x and y as a co-ordinate.
    #10892
    If you save out the raster from Mapper as a geotif you could then extract the x and y of the center of each raster cell.
    #10893
    samreen
    I saved the result as raster but I could not open that in ArcGIS.
    #10894
    did you open the vrt or the tif file?
    You should be able to open it in Arcmap.
    #10895
    samreen
    I tried to open with both .tif and .vrt in Arcmap. When I upload the .vrt or .tif file, Arcmap will just crashed.
    #10896
    ldguethle
    Return-Path:
    by sloti25t09 (Cyrus fastmail-fmjessie45326-15386-git-fastmail-15386) with LMTPA;
    Sun, 01 Oct 2017 18:53:29 -0400
    X-Cyrus-Session-Id: sloti25t09-1144543-1506898409-2-9813896302764753339
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 0.0
    X-Spam-hits: BAYES_00 -1.9, HTML_MESSAGE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
    RCVD_IN_MSPIKE_H5 -1, RCVD_IN_MSPIKE_WL -0.01, SPF_HELO_PASS -0.001,
    SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en, BAYES_USED global,
    SA_VERSION 3.4.0
    X-Spam-source: IP=’104.47.37.78′,
    Host=’mail-cys01nam02on0078.outbound.protection.outlook.com’,
    Country=’US’, FromHeader=’com’, MailFrom=’com’, XOriginatingCountry=’US’
    X-Spam-charsets: plain=’utf-8′, html=’utf-8′
    Received: from mx6 ([10.202.2.205])
    by compute1.internal (LMTPProxy); Sun, 01 Oct 2017 18:53:29 -0400
    Received: from mx6.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id 40E23423C6
    for ; Sun, 1 Oct 2017 18:53:29 -0400 (EDT)
    by mx6.messagingengine.com (Authentication Milter) with ESMTP
    id 037C032ED21;
    Authentication-Results: mx6.messagingengine.com;
    dkim=pass (1024-bit rsa key sha256) header.d=papedawson.onmicrosoft.com [email protected] header.b=ZAKj2mna;
    dmarc=none (p=none) header.from=pape-dawson.com;
    iprev=pass policy.iprev=104.47.37.78 (mail-cys01nam02on0078.outbound.protection.outlook.com);
    spf=pass [email protected] smtp.helo=NAM02-CY1-obe.outbound.protection.outlook.com;
    x-ptr=fail x-ptr-helo=NAM02-CY1-obe.outbound.protection.outlook.com x-ptr-lookup=mail-cys01nam02on0078.outbound.protection.outlook.com;
    x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES256-SHA bits=256/256
    Received-SPF: pass
    (pape-dawson.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:spf.protection.outlook.com’ matched))
    receiver=mx6.messagingengine.com;
    identity=mailfrom;
    client-ip=104.47.37.78
    Received: from NAM02-CY1-obe.outbound.protection.outlook.com (mail-cys01nam02on0078.outbound.protection.outlook.com [104.47.37.78])
    (using TLSv1.2 with cipher ECDHE-RSA-AES256-SHA (256/256 bits))
    by mx6.messagingengine.com (Postfix) with ESMTPS
    for ; Sun, 1 Oct 2017 18:53:27 -0400 (EDT)
    d=PapeDawson.onmicrosoft.com; s=selector1-papedawson-com01b;
    h=From:Date:Subject:Message-ID:Content-Type:MIME-Version;
    bh=VyJhQ/JcGby0TavuyYUbj02CVpKca7FCBjxvJdhQL4g=;
    b=ZAKj2mnaqvP3S6oos2QXatiIRf1g/fgHoVvSaYN4KKvpNHx3uPe89MSjTZDfSsGlW12mXjyYDmEiEnEb7itJyrwaxWu2N/mGzOgLJYXsLsZSodN8aBwsdI5Wu1i5j50b+xG7OkF8mK5mMYu/jsjtJt6Cwd9iVrmg3K54E6NGWBM=
    Received: from DM5PR17CA0058.namprd17.prod.outlook.com (10.175.217.148) by
    CY1PR17MB0614.namprd17.prod.outlook.com (10.164.216.136) with Microsoft SMTP
    Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P256) id
    15.20.77.7; Sun, 1 Oct 2017 22:53:23 +0000
    Received: from BN3NAM04FT047.eop-NAM04.prod.protection.outlook.com
    (2a01:111:f400:7e4e::207) by DM5PR17CA0058.outlook.office365.com
    (2603:10b6:3:13f::20) with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P256) id 15.20.56.8 via Frontend
    Transport; Sun, 1 Oct 2017 22:53:23 +0000
    Authentication-Results: spf=pass (sender IP is 23.96.243.78)
    smtp.mailfrom=pape-dawson.com; n5.nabble.com; dkim=none (message not signed)
    header.d=none;n5.nabble.com; dmarc=bestguesspass action=none
    Received-SPF: Pass (protection.outlook.com: domain of pape-dawson.com
    designates 23.96.243.78 as permitted sender) receiver=protection.outlook.com;
    client-ip=23.96.243.78; helo=us-emailsignatures-cloud.codetwo.com;
    Received: from us-emailsignatures-cloud.codetwo.com (23.96.243.78) by
    BN3NAM04FT047.mail.protection.outlook.com (10.152.92.232) with Microsoft SMTP
    Server (version=TLS1_0, cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA_P384) id
    15.20.56.11 via Frontend Transport; Sun, 1 Oct 2017 22:53:23 +0000
    Received: from NAM01-BN3-obe.outbound.protection.outlook.com (216.32.180.183) by us-emailsignatures-cloud.codetwo.com with CodeTwo SMTP Server (TLS) via SMTP; Sun, 01 Oct 2017 22:53:21 +0000
    Received: from BY2PR17MB0277.namprd17.prod.outlook.com (10.163.67.143) by
    BY2PR17MB0279.namprd17.prod.outlook.com (10.163.67.145) with Microsoft SMTP
    15.20.77.7; Sun, 1 Oct 2017 22:53:16 +0000
    Received: from BY2PR17MB0277.namprd17.prod.outlook.com ([10.163.67.143]) by
    BY2PR17MB0277.namprd17.prod.outlook.com ([10.163.67.143]) with mapi id
    15.20.0077.016; Sun, 1 Oct 2017 22:53:16 +0000
    To: “samreen [via HEC-RAS Help]”
    Subject: Re: x and y co-ordinates of shear stress
    Thread-Topic: x and y co-ordinates of shear stress
    Thread-Index: AQHTOXSUYEkvvlbluUSlt+iTHzohN6LNkboAgABmjYCAASg9gIAAP20AgAARewCAACvNKA==
    Date: Sun, 1 Oct 2017 22:53:16 +0000
    Message-ID: <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>,<[email protected]>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    Authentication-Results-Original: spf=none (sender IP is )
    [email protected];
    x-originating-ip: [70.196.84.142]
    x-ms-publictraffictype: Email
    X-Microsoft-Exchange-Diagnostics-untrusted: 1;BY2PR17MB0279;20:VczXjyVYwuhWHlSvNbcVBVFhINrAA9YYyCKn6Yw19SEk/ejk8xl3TMb/R4kR27Tm6lHKrojKF0eZciCL/4wmWDV07o+Gdv3kDQyKenJClZGu9OyyH694oBa7mbi5YWqi1CxM2O8y7YK7vYL35LwH1R15SgKm3iphcWxGZnYeVZ8=
    x-ms-exchange-antispam-srfa-diagnostics: SSOS;
    X-MS-Office365-Filtering-Correlation-Id: 631c1609-aeae-409a-5b6a-08d5091f3803
    X-Microsoft-Antispam-Untrusted: UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:BY2PR17MB0279;
    X-MS-TrafficTypeDiagnostic: BY2PR17MB0279:|CY1PR17MB0614:
    x-exchange-antispam-report-test: UriScan:;UriScan:;
    X-Microsoft-Antispam-PRVS:
    x-exchange-antispam-report-cfa-test:
    =?us-ascii?Q?BCL:0;PCL:0;RULEID:(100000700101)(100105000095)(100000701101?=
    =?us-ascii?Q?)(100105300095)(100000702101)(100105100095)(6040450)(2401047?=
    =?us-ascii?Q?)(8121501046)(5005006)(10201501046)(93006095)(3002001)(10000?=
    =?us-ascii?Q?0703101)(100105400095)(6041248)(20161123564025)(201703131423?=
    =?us-ascii?Q?075)(201702281528075)(201703061421075)(201703061406153)(2016?=
    =?us-ascii?Q?1123558100)(20161123560025)(20161123555025)(20161123562025)(?=
    =?us-ascii?Q?6072148)(201708071742011)(100000704101)(100105200095)(100000?=
    =?us-ascii?Q?705101)(100105500095);SRVR:BY2PR17MB0279;BCL:0;PCL:0;RULEID:?=
    =?us-ascii?Q?(100000800101)(100110000095)(100000801101)(100110300095)(100?=
    =?us-ascii?Q?000802101)(100110100095)(100000803101)(100110400095)(1000008?=
    =?us-ascii?Q?04101)(100110200095)(100000805101)(100110500095);SRVR:BY2PR1?=
    =?us-ascii?Q?7MB0279;BCL:0;PCL:0;RULEID:(100000700101)(100105000095)(1000?=
    =?us-ascii?Q?00701101)(100105300095)(100000702101)(100105100095)(6040450)?=
    =?us-ascii?Q?(2401047)(5005006)(8121501046)(93006095)(93004095)(102015010?=
    =?us-ascii?Q?46)(100000703101)(100105400095)(3002001)(6041248)(2017031314?=
    =?us-ascii?Q?23075)(201702281528075)(201703061421075)(201703061406153)(20?=
    =?us-ascii?Q?161123560025)(20161123558100)(20161123555025)(20161123564025?=
    =?us-ascii?Q?)(20161123562025)(6072148)(201708071742011)(100000704101)(10?=
    =?us-ascii?Q?0105200095)(100000705101)(100105500095);SRVR:CY1PR17MB0614;B?=
    =?us-ascii?Q?CL:0;PCL:0;RULEID:(100000800101)(100110000095)(100000801101)?=
    =?us-ascii?Q?(100110300095)(100000802101)(100110100095)(100000803101)(100?=
    =?us-ascii?Q?110400095)(100000804101)(100110200095)(100000805101)(1001105?=
    =?us-ascii?Q?00095);SRVR:CY1PR17MB0614;?=
    x-forefront-prvs: 0447DB1C71
    X-Forefront-Antispam-Report-Untrusted: SFV:NSPM;SFS:(10009020)(376002)(39830400002)(346002)(377454003)(24454002)(189002)(199003)(14971765001)(606006)(81156014)(7736002)(50986999)(7066003)(5660300001)(54356999)(76176999)(6306002)(77096006)(6246003)(54896002)(2950100002)(478600001)(97736004)(25786009)(316002)(966005)(72206003)(86362001)(189998001)(2900100001)(99286003)(6512007)(93886005)(81166006)(83716003)(8936002)(10126004)(14454004)(6486002)(53546010)(82746002)(3660700001)(68736007)(8676002)(236005)(53936002)(33656002)(3280700002)(106356001)(2906002)(229853002)(6506006)(102836003)(6116002)(3846002)(6436002)(66066001)(101416001)(36756003)(105586002);DIR:OUT;SFP:1101;SCL:1;SRVR:BY2PR17MB0279;H:BY2PR17MB0277.namprd17.prod.outlook.com;FPR:;SPF:None;PTR:InfoNoRecords;MX:1;A:1;LANG:en;
    received-spf: None (protection.outlook.com: pape-dawson.com does not designate
    permitted sender hosts)
    SpamDiagnosticOutput: 1:99
    SpamDiagnosticMetadata: NSPM
    boundary=”_000_7F3E529CA2434571982E05612616CB19papedawsoncom_”
    MIME-Version: 1.0
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BY2PR17MB0279
    X-CodeTwo-MessageID: 20171001225321.0b1a596b-4fe2-4e32-9d9f-c105f14df9b7@us-emailsignatures-cloud.codetwo.com
    X-CodeTwoProcessed: true
    X-EOPAttributedMessage: 0
    X-MS-Exchange-Transport-CrossTenantHeadersStripped: BN3NAM04FT047.eop-NAM04.prod.protection.outlook.com
    X-Forefront-Antispam-Report:
    CIP:23.96.243.78;IPV:NLI;CTRY:;EFV:NLI;SFV:NSPM;SFS:(10009020)(346002)(39830400002)(376002)(2980300002)(438002)(199003)(377454003)(189002)(24454002)(575784001)(356003)(86362001)(33656002)(966005)(93886005)(8676002)(5660300001)(8936002)(478600001)(25786009)(2900100001)(4546004)(30436002)(6512007)(7066003)(82746002)(66066001)(76176999)(14454004)(54356999)(54896002)(189998001)(6246003)(606006)(53546010)(512874002)(6306002)(106466001)(50986999)(236005)(3846002)(10126004)(83716003)(102836003)(2950100002)(6116002)(2906002)(72206003)(229853002)(99286003)(6506006)(77096006)(6486002)(7636002)(246002)(14971765001)(16586007)(106002)(36756003)(84326002)(7736002)(316002)(7596002);DIR:OUT;SFP:1101;SCL:1;SRVR:CY1PR17MB0614;H:us-emailsignatures-cloud.codetwo.com;FPR:;SPF:Pass;PTR:us-emailsignatures-cloud.codetwo.com;A:1;MX:1;LANG:en;
    X-Microsoft-Exchange-Diagnostics: 1;BN3NAM04FT047;1:X0Z+PvucisJEHFphnrIAms+CrxPYeQS5BKhVtXSIlFgq39SMt6OlyV7FWRAVQEo/0sXFhSJtk4hHj1HcAFOVMKhYBW2lSmmnYvLUveuRHT4gRCEGS7Dwj+6964IdcQYp
    X-Microsoft-Antispam:
    UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(8251501002)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:CY1PR17MB0614;
    1;CY1PR17MB0614;3:NKKxL2MeHtlTV1BKMv9b76Mfr4fySuQ98dg0xiJGV7cWjfDKXU9GPIZUqCF7kvJoOSnKPWbxll0+BZTCGedYO1mY2aBWJ3fHaSi3a9uQ5ik1V5oQqSfKU3ptQ0oFMNIAjS9ulvBuQm0w0dleC1v2dXnJVI5PI5siLZv5Q2+04PjPK52jsHfUQFC3Qkk/5P6+57NH9z9m2Itvilx0rq4sLr4YIxgMkIWnq5s2PExl7n9ZGa37pepvU8wuf9yXnGu9+ipfip3m5r53chbcBPrNZ0ShsDKBcQ1PlehjNujszdH+knmA5WLkIoumNK9NtfbCyJNUcGqhJ3tk/ILeVA2dmw==;25:1GAx4xQs6LO/ebrmFc9W4T/WeTGbabFiGS1XmORjPrl8DECA3Nj9E2gADsNT54YMVDvgVo9E9aQo+H7c/KWqL80cF3+aGirrSe36cG1AuVrlLr9+jgJ0PfMn5TjNMakqFCkJY6CIERiF+KbM7Qam5br5LI2NAmBPqA04AfwqxjeolnZFqXnBUjs3eYi8s/T2xUcMHNZk+L1UYORogvV4AE+MCyt2sqhP7GZG+uRZ5HedIsQraCHO464ZppDUvfFeBdqHnazk2LOw+BBEa6nNVOz3t/C/iHzTxpG+Ur4NBRQKl2hseeIkXXuAgGBjkVdqDE0wahKHCclfmRPVg92E1w==;31:c4+xZVLVu0VX91z5seXe7vMsYdtIdCiXnSHb6MNSktVUrlcFZ0C3miGVSkuu1aVO9a1zvuswBuoTfXlhqwzEkkJ9og46ug4/bK4x21/K3PNgWU8e1roIgqezdyOnovfiheUiEWRi4zvuMHghtFh+qjTqmFT1BouqXCanVJ1eF86PZI9IgPlDL79RVA8Nl0IoeN1UwCowHi2ivAeYhVuasdkoWa56GzkKEaL6Y4nRmlY=
    1;CY1PR17MB0614;20: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;4:usKlo42waZR7smGvi91YekamnknITVoASzavzmgxqD8mAqvm+shA/LjBQeHfivakN783W01R9HWRRRaYTKGyHQIawQ0N5/6S7xZB/fRRC31a5vxyiqF1NvlHf8pCPJ/AxwLWw+qm4C9Uj4q7TXVu1SQ3bjMtecfyQDGwPdYnRFW5haSnxpqq8ZP5FBDDi49HIKt8QzX88wOx9zIj/D7FctV1jL2eLu1OBHHk5GiQfcG+MBA3HKr8DJDQMU8DqDVs
    X-Forefront-PRVS: 0447DB1C71
    =?us-ascii?Q?1;CY1PR17MB0614;23:wgmE6e2H2zMTKzPemT0j2c7aKNETqfxjWhYvcO0sG?=
    =?us-ascii?Q?sb8oGShwIgst5JPzNQuT+onLcdS7mGcO6yYZxvIfRosfC9/loOoXADxToQpp?=
    =?us-ascii?Q?o4qeGnkzTRrFq0CCrp27pewYsRn53MrrV4UGJZbJYYQV/og6dEqPkoxLIx4D?=
    =?us-ascii?Q?gl6+QBUUrFq9pJ+6nrCy8sIbWs3BqqEIYgKfTq1p9FidcAYsj1qKEmxQJBtc?=
    =?us-ascii?Q?lFZSow254Wdy9+8yB70gTlgFDNm6pBdfiPtCnrgl05l6R/ZeYH+9ETGfOKmJ?=
    =?us-ascii?Q?JOGtvZMqdoABLFvvH0wRruL0ZowAl5uTNoRrCh+ZrxfJQbRlnK1rs/oqI8HO?=
    =?us-ascii?Q?OWouIowWm2N8iFj9FAuj5R2Hfs51yRydoCiXBQeO/WOJPAjBs0/Ule/4+tum?=
    =?us-ascii?Q?QcgCp15a9iMXQE2/r+3vdAAlCeh0MmYiQrD+gbsjrna5v5XSj1mvePQCqd7F?=
    =?us-ascii?Q?aXeF0lvnLtNqbgSOyzHXmZ+SrRyQRJP5m4RypiQzkwJqGm/TAEGcreeitfbR?=
    =?us-ascii?Q?ChR0Ec8dREm2tDXcVO6uW1SsjWRHWAzKRyW4spe7sTuFhwydGib7W2SmMhJK?=
    =?us-ascii?Q?NJTvd+uydPt0oo/P9YcFxt+RE2mYCzJmC7yI2MTWS0stqqKYSFMnfOo2mSrb?=
    =?us-ascii?Q?VTgQlZ7s8bretD5CfyitaOCehaLE8Gk1ihZtZiCXuA+2hxoA6zAE52sBFOyP?=
    =?us-ascii?Q?5uMvfYqIFfzorLhiOimFlXw/apJASruUPsiA3lxbTpHr0qx4ZxMSJenY5Ijb?=
    =?us-ascii?Q?vRU/jGgvLWeUCRaPHgNSKlCwrxRFdJPQImdop/e5o4TI7hV4MLnFbXu6z++l?=
    =?us-ascii?Q?3JZI8tQ+yrPi154rZL9FaoDPFJTlM7E/xdKMq1S68A+ESRzv2vxkWnW93vBI?=
    =?us-ascii?Q?NCz4l37S8x29tN5Fb2v5idIYw+gWyTH6/1s2uMZlU6qE5bTaIEbGH5CyOOsZ?=
    =?us-ascii?Q?oZsfsVO88oAoQfqYRZYokrKbB+dn6+fI2PaA4GUq/kGWkLzSrO25yHRgjWsF?=
    =?us-ascii?Q?5YcnO3ytijolkvoDoGZkpqKqIEHmNTeHERpyqyQ91Vfvf5zR812vnt7NTqpE?=
    =?us-ascii?Q?VL/TCafacB8577UkF4VNVfjMweCdbdOS1VC/jpOLpenCYqhslfLUX3bwpmNL?=
    =?us-ascii?Q?KYOuZWeQDx0QQQWmiBF4daPo49BkJPjJh5SpWVeIo9/pzYjj8KV8qe1FSgxY?=
    =?us-ascii?Q?1CLfztmmFxvWd2+8wZvl++YjVCyTAlLjddTCji0mxnjKOfBnfyEJV35suzBj?=
    =?us-ascii?Q?adupWOEXQuhBhwcGFILzOwXU6OHwFw53D9zFsgMLkwwy2JUDZiJbU4GYA8WY?=
    =?us-ascii?Q?xEgixjSFt+u+2OKuu/UZk+tpQ6bmHs+WaVW2uYdif5pblO2VfB3Tgdw5nE99?=
    =?us-ascii?Q?+1lRPOOzSr+6h6f3Gz8dAvu5stk59r72UltFJy78VzxaPJoVV7FORYxDHOlE?=
    =?us-ascii?Q?abnoDhy4g=3D=3D?=
    1;CY1PR17MB0614;6:RIrSTY7vbnkVmq7FrgiXkCkWU3BjmLfsL4b2ScdKAmicjAYitB2BJJZBZkAshZ481NVM9/xzBrdJRzgiV0Cw0pVpiITfbA/UWkrZ/Jg/QnvgnLnYasx+w2ZKurG3u61mTBqH5mzkakiH+ls/JY16Q9R8WLExJao3dA8e1l0Oy0OtGNEkFETtZ9mY/Iw0y3Mz1gFuPUY4w6gVUDJF0lRMMkMLB5VISJTI4vcnY3i4k9QRj4WH3bJxvx27FW237TGo96B7yHbEgfk2bl3VVBsh3LgxzvgQoD3uPA505Lc6CM5zinJBrtbSeaOYgDXqBqVSjiHX3/PgjZpibh77OxSJWQ==;5:pNBUgljCcLIByGvqokMKkxMxOJJXSPspUeKXr5nKG6o51cUk62G4PAX++WY09D3dG2MBb0rqMbzxAYT7dBhCyZdVVhEOWv/KDKIglAXQyh2CE3oy49luaYCAoajrQu044fElMFzn5Euz/RLIO6810fLUkgW8M/JuUBEwU2j1Uvg=;24:3xtD2pRcjjM64IUrxJ9R7IDZ0JnnDmYQnPxLfMMoS087Iwtyt2UWnk8yt3LlEWwq1KSX/amMfNMOu7LEfKqrrSths3J/kHX7pCRZfC33lDY=;7:y2JShUWyPYeT3RWwmRBi/yo3wgiBxCSkY36M8sI9QiFbnc8D4RVxDNg22zY2uVD8WmHUKX1jleypgWDmQ0HkArYBEh+k9MufZ1VF9Ym4u9kVbn5ZERr6ZZa+7LqXt07En6QMHT88Dsb8Z/I6+D2osdgepmAkCKvLACOP2yEwnQuPBUN6hPn28QJH1HXvaIyzKIlYTqqDBE3bwwb38z3Jh8BxOBCXB7VxyUGfR1LgwvM=
    1;CY1PR17MB0614;20:zTiwqe57GC8ZDJHORJmDmJ8panL0G3rnUV7GS8DqlOpP8xDC9Rgx/j3CRdcqyjm20HaBnALT7MNO1PtykHLW1Xhgz3YMiwBBYK0aznmkTJFEsE1rsTNyi4J+Pfc5HsuEb/3hdwtgqO5ayzGRjIJQT+m1+gb3fNWE0e1AtVi0Pw8=
    X-OriginatorOrg: pape-dawson.com
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 01 Oct 2017 22:53:23.0548
    (UTC)
    X-MS-Exchange-CrossTenant-Id: 687eedc7-08d3-4a57-8c60-2fc58e745300
    X-MS-Exchange-CrossTenant-OriginalAttributedTenantConnectingIp: TenantId=687eedc7-08d3-4a57-8c60-2fc58e745300;Ip=[23.96.243.78];Helo=[us-emailsignatures-cloud.codetwo.com]
    X-MS-Exchange-CrossTenant-FromEntityHeader: HybridOnPrem
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: CY1PR17MB0614
    –_000_7F3E529CA2434571982E05612616CB19papedawsoncom_
    Content-Type: text/plain; charset=”utf-8″
    VXBsb2FkPyBZb3UgbWVhbiBhZGQgdGhlIGxheWVyPw0KDQpJIHdvdWxkIGRlbGV0ZSB0aWYgYW5k
    IHZydCBhbmQgcmVjcmVhdGUgaXQuIFRyeSBhIG5ldyBhcmMgbWFwIGRvY3VtZW50Lg0KDQpXaGF0
    IGlzIHRoZSBzcGF0aWFsIHJlc29sdXRpb24gb2YgeW91ciBoZWNyYXMgdGVycmFpbj8NCg0KDQpM
    ZWUgdm9uIEd5bnotR3VldGhsZSwgUC5FLiB8IFByb2plY3QgRW5naW5lZXINClBhcGUtRGF3c29u
    IEVuZ2luZWVycywgSW5jLg0KVEJQRSBGaXJtIFJlZ2lzdHJhdGlvbiAjNDcwIHwgVEJQTFMgRmly
    bSBSZWdpc3RyYXRpb24gIzEwMTkzOTc0DQoNCjEwMzMzIFJpY2htb25kIEF2ZS4sIFN1aXRlIDkw
    MCwgSG91c3RvbiwgVFggNzcwNDINClA6IDcxMy00MjgtMjQwMCB8IEU6IEx2b25HeW56LUd1ZXRo
    bGVAcGFwZS1kYXdzb24uY29tIHwgdmNhcmQ8ZnRwOi8vdmNhcmQ6cERfMjAwMEBmdHAucGFwZS1k
    YXdzb24uY29tL0xlZSUyMHZvbiUyMEd5bnotR3VldGhsZS52Y2Y+DQoNCkhvdXN0b24gfCBTYW4g
    QW50b25pbyB8IEF1c3RpbiB8IEZvcnQgV29ydGggfCBEYWxsYXMNCg0KQ09ORklERU5USUFMSVRZ
    IE5PVElDRQ0KVGhpcyBlbGVjdHJvbmljIG1haWwgdHJhbnNtaXNzaW9uIG1heSBiZSBjb25maWRl
    bnRpYWwsIG1heSBiZSBwcml2aWxlZ2VkLCBhbmQgc2hvdWxkIGJlIHJlYWQgb3IgcmV0YWluZWQg
    b25seSBieSB0aGUgaW50ZW5kZWQgcmVjaXBpZW50Lg0KSWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhp
    cyB0cmFuc21pc3Npb24gaW4gZXJyb3IsIHBsZWFzZSBpbW1lZGlhdGVseSBub3RpZnkgdGhlIHNl
    bmRlciBhbmQgZGVsZXRlIGl0IGZyb20geW91ciBzeXN0ZW0uDQoNCk9uIE9jdCAxLCAyMDE3LCBh
    dCAzOjE2IFBNLCBzYW1yZWVuIFt2aWEgSEVDLVJBUyBIZWxwXSA8bWwrczEwOTExMTJuNDU1N2g0
    QG41Lm5hYmJsZS5jb208bWFpbHRvOm1sK3MxMDkxMTEybjQ1NTdoNEBuNS5uYWJibGUuY29tPj4g
    d3JvdGU6DQoNCkkgdHJpZWQgdG8gb3BlbiB3aXRoIGJvdGggLnRpZiBhbmQgLnZydCBpbiBBcmNt
    YXAuIFdoZW4gSSB1cGxvYWQgdGhlIC52cnQgb3IgLnRpZiBmaWxlLCBBcmNtYXAgd2lsbCBqdXN0
    IGNyYXNoZWQuDQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpJZiB5b3UgcmVw
    bHkgdG8gdGhpcyBlbWFpbCwgeW91ciBtZXNzYWdlIHdpbGwgYmUgYWRkZWQgdG8gdGhlIGRpc2N1
    c3Npb24gYmVsb3c6DQpodHRwOi8vaGVjLXJhcy1oZWxwLjEwOTExMTIubjUubmFiYmxlLmNvbS94
    LWFuZC15LWNvLW9yZGluYXRlcy1vZi1zaGVhci1zdHJlc3MtdHA0NTQ1cDQ1NTcuaHRtbA0KVG8g
    dW5zdWJzY3JpYmUgZnJvbSB4IGFuZCB5IGNvLW9yZGluYXRlcyBvZiBzaGVhciBzdHJlc3MsIGNs
    aWNrIGhlcmU8aHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20vdGVtcGxh
    dGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT00NTQ1JmNv
    ZGU9YkhadmJtZDVibm90WjNWbGRHaHNaVUJ3WVhCbExXUmhkM052Ymk1amIyMThORFUwTlh3dE1U
    STVNamsyTURJeE1nPT0+Lg0KTkFNTDxodHRwOi8vaGVjLXJhcy1oZWxwLjEwOTExMTIubjUubmFi
    YmxlLmNvbS90ZW1wbGF0ZS9OYW1sU2VydmxldC5qdHA/bWFjcm89bWFjcm9fdmlld2VyJmlkPWlu
    c3RhbnRfaHRtbCUyMW5hYmJsZSUzQWVtYWlsLm5hbWwmYmFzZT1uYWJibGUubmFtbC5uYW1lc3Bh
    Y2VzLkJhc2ljTmFtZXNwYWNlLW5hYmJsZS52aWV3LndlYi50ZW1wbGF0ZS5OYWJibGVOYW1lc3Bh
    Y2UtbmFiYmxlLnZpZXcud2ViLnRlbXBsYXRlLk5vZGVOYW1lc3BhY2UmYnJlYWRjcnVtYnM9bm90
    aWZ5X3N1YnNjcmliZXJzJTIxbmFiYmxlJTNBZW1haWwubmFtbC1pbnN0YW50X2VtYWlscyUyMW5h
    YmJsZSUzQWVtYWlsLm5hbWwtc2VuZF9pbnN0YW50X2VtYWlsJTIxbmFiYmxlJTNBZW1haWwubmFt
    bD4NCg==
    Content-Type: text/html; charset=”utf-8″
    PGh0bWw+DQo8aGVhZD4NCjxtZXRhIGh0dHAtZXF1aXY9IkNvbnRlbnQtVHlwZSIgY29udGVudD0i
    dGV4dC9odG1sOyBjaGFyc2V0PXV0Zi04Ij4NCjwvaGVhZD4NCjxib2R5IGRpcj0iYXV0byI+DQo8
    ZGl2PjwvZGl2Pg0KPGRpdj5VcGxvYWQ/IFlvdSBtZWFuIGFkZCB0aGUgbGF5ZXI/PC9kaXY+DQo8
    ZGl2Pjxicj4NCjwvZGl2Pg0KPGRpdj5JIHdvdWxkIGRlbGV0ZSB0aWYgYW5kIHZydCBhbmQgcmVj
    cmVhdGUgaXQuIFRyeSBhIG5ldyBhcmMgbWFwIGRvY3VtZW50LiZuYnNwOzwvZGl2Pg0KPGRpdj48
    YnI+DQo8L2Rpdj4NCjxkaXY+V2hhdCBpcyB0aGUgc3BhdGlhbCByZXNvbHV0aW9uIG9mIHlvdXIg
    aGVjcmFzIHRlcnJhaW4/PC9kaXY+DQo8ZGl2Pjxicj4NCgo8UCBzdHlsZT0iRk9OVC1TSVpFOiA5
    cHQ7IEZPTlQtRkFNSUxZOiBWZXJkYW5hIj48L1A+CjxQIHN0eWxlPSJGT05ULVNJWkU6IDlwdDsg
    Rk9OVC1GQU1JTFk6IFZlcmRhbmEiPjxTUEFOIApzdHlsZT0iRk9OVC1GQU1JTFk6IFZlcmRhbmEi
    PjxTVFJPTkc+PFNQQU4gc3R5bGU9IkZPTlQtU0laRTogMTAuNXB0Ij5MZWUgdm9uIEd5bnotR3Vl
    dGhsZSwgUC5FLjwvU1BBTj48L1NUUk9ORz4gPFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDEwcHQ7
    IENPTE9SOiAjNjY2NjY2Ij58IDxTVFJPTkc+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDlwdCI+
    UHJvamVjdCBFbmdpbmVlcjwvU1BBTj48L1NUUk9ORz48L1NQQU4+PC9TUEFOPjxCUj48U1BBTiAK
    c3R5bGU9IkZPTlQtU0laRTogOXB0OyBGT05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxl
    PSJGT05ULVNJWkU6IDlwdDsgQ09MT1I6ICM2NjY2NjYiPjxTVFJPTkc+UGFwZS1EYXdzb24gRW5n
    aW5lZXJzLCAKSW5jLjwvU1RST05HPjwvU1BBTj48L1NQQU4+PEJSPjxTUEFOIHN0eWxlPSJGT05U
    LVNJWkU6IDlwdCI+PFNQQU4gCnN0eWxlPSJDT0xPUjogIzY2NjY2NiI+PFNQQU4gc3R5bGU9IkZP
    TlQtU0laRTogOXB0OyBGT05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULVNJ
    WkU6IDlwdCI+VEJQRSBGaXJtIFJlZ2lzdHJhdGlvbiAjNDcwIHwgVEJQTFMgRmlybSBSZWdpc3Ry
    YXRpb24gCiMxMDE5Mzk3NDwvU1BBTj48L1NQQU4+PC9TUEFOPjwvU1BBTj48L1A+CjxQIHN0eWxl
    PSJGT05ULVNJWkU6IDlwdDsgRk9OVC1GQU1JTFk6IFZlcmRhbmEiPjxTUEFOIApzdHlsZT0iRk9O
    VC1TSVpFOiA5cHQ7IEZPTlQtRkFNSUxZOiBWZXJkYW5hOyBDT0xPUjogIzAwMDAwMCI+PFNQQU4g
    CnN0eWxlPSJGT05ULVNJWkU6IDlwdDsgRk9OVC1GQU1JTFk6IFZlcmRhbmE7IENPTE9SOiAjNjY2
    NjY2Ij4xMDMzMyBSaWNobW9uZCAKQXZlLiwgU3VpdGUgOTAwLCBIb3VzdG9uLCBUWCA3NzA0MiA8
    L1NQQU4+PC9TUEFOPjxCUj48U1BBTiAKc3R5bGU9IkZPTlQtRkFNSUxZOiBWZXJkYW5hOyBDT0xP
    UjogIzY2NjY2NiI+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDlwdCI+PFNUUk9ORz48U1BBTiAK
    c3R5bGU9IkNPTE9SOiAjMDAwMDAwIj5QOjwvU1BBTj48L1NUUk9ORz4mbmJzcDs3MTMtNDI4LTI0
    MDAmbmJzcDt8IDxTVFJPTkc+PFNQQU4gCnN0eWxlPSJDT0xPUjogIzAwMDAwMCI+RTo8L1NQQU4+
    PC9TVFJPTkc+IEx2b25HeW56LUd1ZXRobGVAcGFwZS1kYXdzb24uY29tIHwgPEEgCnN0eWxlPSJU
    RVhULURFQ09SQVRJT046IG5vbmU7IENPTE9SOiAjNjY2NjY2IiAKaHJlZj0iZnRwOi8vdmNhcmQ6
    cERfMjAwMEBmdHAucGFwZS1kYXdzb24uY29tL0xlZSB2b24gR3luei1HdWV0aGxlLnZjZiI+PFNU
    Uk9ORz52Y2FyZDwvU1RST05HPjwvQT48L1NQQU4+PC9TUEFOPjwvUD4KPFAgc3R5bGU9IkZPTlQt
    U0laRTogOXB0OyBGT05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULUZBTUlM
    WTogVmVyZGFuYTsgQ09MT1I6ICM2NjY2NjYiPjxTUEFOIApzdHlsZT0iRk9OVC1TSVpFOiA5cHQi
    PjxTVFJPTkc+SG91c3RvbiB8IFNhbiBBbnRvbmlvIHwgQXVzdGluIHwgRm9ydCBXb3J0aCB8IApE
    YWxsYXM8L1NUUk9ORz48L1NQQU4+PC9TUEFOPjwvUD4KPFAgc3R5bGU9IkZPTlQtU0laRTogOXB0
    OyBGT05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDdwdDsgRk9O
    VC1GQU1JTFk6IFZlcmRhbmE7IENPTE9SOiAjNjY2NjY2OyBMSU5FLUhFSUdIVDogMTJwdCI+PEVN
    PjxTUEFOIApzdHlsZT0iRk9OVC1TSVpFOiA3LjVwdCI+Q09ORklERU5USUFMSVRZIE5PVElDRTxC
    Uj5UaGlzIGVsZWN0cm9uaWMgbWFpbCAKdHJhbnNtaXNzaW9uIG1heSBiZSBjb25maWRlbnRpYWws
    IG1heSBiZSBwcml2aWxlZ2VkLCBhbmQgc2hvdWxkIGJlIHJlYWQgb3IgCnJldGFpbmVkIG9ubHkg
    YnkgdGhlIGludGVuZGVkIHJlY2lwaWVudC48QlI+SWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhpcyAK
    dHJhbnNtaXNzaW9uIGluIGVycm9yLCBwbGVhc2UgaW1tZWRpYXRlbHkgbm90aWZ5IHRoZSBzZW5k
    ZXIgYW5kIGRlbGV0ZSBpdCBmcm9tIAp5b3VyIHN5c3RlbS48L1NQQU4+PC9FTT48L1NQQU4+PC9Q
    Pk9uIE9jdCAxLCAyMDE3LCBhdCAzOjE2IFBNLCBzYW1yZWVuIFt2aWEgSEVDLVJBUyBIZWxwXSAm
    bHQ7PGEgaHJlZj0ibWFpbHRvOm1sJiM0MztzMTA5MTExMm40NTU3aDRAbjUubmFiYmxlLmNvbSI+
    bWwmIzQzO3MxMDkxMTEybjQ1NTdoNEBuNS5uYWJibGUuY29tPC9hPiZndDsgd3JvdGU6PGJyPg0K
    PGJyPg0KPC9kaXY+DQo8YmxvY2txdW90ZSB0eXBlPSJjaXRlIj4NCjxkaXY+SSB0cmllZCB0byBv
    cGVuIHdpdGggYm90aCAudGlmIGFuZCAudnJ0IGluIEFyY21hcC4gV2hlbiBJIHVwbG9hZCB0aGUg
    LnZydCBvciAudGlmIGZpbGUsIEFyY21hcCB3aWxsIGp1c3QgY3Jhc2hlZC4NCjxicj4NCjxicj4N
    CjxociBub3NoYWRlPSJub3NoYWRlIiBzaXplPSIxIiBjb2xvcj0iI2NjY2NjYyI+DQo8ZGl2IHN0
    eWxlPSJjb2xvcjojNDQ0OyBmb250OiAxMnB4IHRhaG9tYSxnZW5ldmEsaGVsdmV0aWNhLGFyaWFs
    LHNhbnMtc2VyaWY7Ij4NCjxkaXYgc3R5bGU9ImZvbnQtd2VpZ2h0OmJvbGQiPklmIHlvdSByZXBs
    eSB0byB0aGlzIGVtYWlsLCB5b3VyIG1lc3NhZ2Ugd2lsbCBiZSBhZGRlZCB0byB0aGUgZGlzY3Vz
    c2lvbiBiZWxvdzo8L2Rpdj4NCjxhIGhyZWY9Imh0dHA6Ly9oZWMtcmFzLWhlbHAuMTA5MTExMi5u
    NS5uYWJibGUuY29tL3gtYW5kLXktY28tb3JkaW5hdGVzLW9mLXNoZWFyLXN0cmVzcy10cDQ1NDVw
    NDU1Ny5odG1sIj5odHRwOi8vaGVjLXJhcy1oZWxwLjEwOTExMTIubjUubmFiYmxlLmNvbS94LWFu
    ZC15LWNvLW9yZGluYXRlcy1vZi1zaGVhci1zdHJlc3MtdHA0NTQ1cDQ1NTcuaHRtbDwvYT4NCjwv
    ZGl2Pg0KPGRpdiBzdHlsZT0iY29sb3I6IzY2NjsgZm9udDogMTFweCB0YWhvbWEsZ2VuZXZhLGhl
    bHZldGljYSxhcmlhbCxzYW5zLXNlcmlmO21hcmdpbi10b3A6LjRlbTtsaW5lLWhlaWdodDoxLjVl
    bSI+DQpUbyB1bnN1YnNjcmliZSBmcm9tIHggYW5kIHkgY28tb3JkaW5hdGVzIG9mIHNoZWFyIHN0
    cmVzcywgPGEgaHJlZj0iaHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20v
    dGVtcGxhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmYW1wO25v
    ZGU9NDU0NSZhbXA7Y29kZT1iSFp2Ym1kNWJub3RaM1ZsZEdoc1pVQndZWEJsTFdSaGQzTnZiaTVq
    YjIxOE5EVTBOWHd0TVRJNU1qazJNREl4TWc9PSI+DQpjbGljayBoZXJlPC9hPi48YnI+DQo8YSBo
    cmVmPSJodHRwOi8vaGVjLXJhcy1oZWxwLjEwOTExMTIubjUubmFiYmxlLmNvbS90ZW1wbGF0ZS9O
    YW1sU2VydmxldC5qdHA/bWFjcm89bWFjcm9fdmlld2VyJmFtcDtpZD1pbnN0YW50X2h0bWwlMjFu
    YWJibGUlM0FlbWFpbC5uYW1sJmFtcDtiYXNlPW5hYmJsZS5uYW1sLm5hbWVzcGFjZXMuQmFzaWNO
    YW1lc3BhY2UtbmFiYmxlLnZpZXcud2ViLnRlbXBsYXRlLk5hYmJsZU5hbWVzcGFjZS1uYWJibGUu
    dmlldy53ZWIudGVtcGxhdGUuTm9kZU5hbWVzcGFjZSZhbXA7YnJlYWRjcnVtYnM9bm90aWZ5X3N1
    YnNjcmliZXJzJTIxbmFiYmxlJTNBZW1haWwubmFtbC1pbnN0YW50X2VtYWlscyUyMW5hYmJsZSUz
    QWVtYWlsLm5hbWwtc2VuZF9pbnN0YW50X2VtYWlsJTIxbmFiYmxlJTNBZW1haWwubmFtbCIgcmVs
    PSJub2ZvbGxvdyIgc3R5bGU9ImZvbnQ6OXB4IHNlcmlmIj5OQU1MPC9hPg0KPC9kaXY+DQo8L2Rp
    dj4NCjwvYmxvY2txdW90ZT4NCjwvYm9keT4NCjwvaHRtbD4NCg==
    –_000_7F3E529CA2434571982E05612616CB19papedawsoncom_–
    #10897
    samreen
    Yes, adding the layer.
    The resolution of terrain is 1 feet x 1 feet. I tried creating smaller number of mesh elements. I did not face that problem. I am guessing, its due to resolution. Because of that I am wondering if I could extract from HDF.
    #10898
    What are you modeling that requires less than 1ft elements?
    #10899
    samreen
    I am working on canyon.
    #10900
    Toby
    You can get facepoint coords in the HDF file at “Geometry/2D Flow Areas/”,your mesh name,”/FacePoints Coordinate”
    #10913
    ldguethle
    Return-Path:
    Mon, 02 Oct 2017 07:02:25 -0400
    X-Cyrus-Session-Id: sloti25t09-1546657-1506942145-2-3997597270615363420
    X-Spam-score: 0.0
    RCVD_IN_MSPIKE_H2 -2.8, SPF_HELO_PASS -0.001, SPF_PASS -0.001,
    URI_HEX 1.122, LANGUAGES en, BAYES_USED global, SA_VERSION 3.4.0
    X-Spam-source: IP=’104.47.33.61′,
    Host=’mail-bn3nam01on0061.outbound.protection.outlook.com’, Country=’US’,
    by compute1.internal (LMTPProxy); Mon, 02 Oct 2017 07:02:25 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id 745BD422BE
    for ; Mon, 2 Oct 2017 07:02:23 -0400 (EDT)
    id 82E029E223F;
    dkim=pass (1024-bit rsa key sha256) header.d=papedawson.onmicrosoft.com [email protected] header.b=UXvfIsUF;
    iprev=pass policy.iprev=104.47.33.61 (mail-bn3nam01on0061.outbound.protection.outlook.com);
    spf=pass [email protected] smtp.helo=NAM01-BN3-obe.outbound.protection.outlook.com;
    x-ptr=fail x-ptr-helo=NAM01-BN3-obe.outbound.protection.outlook.com x-ptr-lookup=mail-bn3nam01on0061.outbound.protection.outlook.com;
    Received-SPF: pass
    identity=mailfrom;
    client-ip=104.47.33.61
    Received: from NAM01-BN3-obe.outbound.protection.outlook.com (mail-bn3nam01on0061.outbound.protection.outlook.com [104.47.33.61])
    for ; Mon, 2 Oct 2017 07:02:22 -0400 (EDT)
    bh=OLlGVs+I3At2QG22QFx8VtgUNgv74izYwXIpuedIcko=;
    b=UXvfIsUFCfX0u95RDSo3IJXQKSUenviFYCitP/OZeW7gocYCW2tONDsaS8dXiR9y8DdZPcww3Kc25vlnA104JEwhpJBPv2AjBNRmuGAUsQewYwW4N6RttqvHkjpvE/9ywfJpZRfdl9/4onXTdYMWWWh4epTQ0WD4DJmycRpcAv8=
    Received: from BN6PR1701CA0013.namprd17.prod.outlook.com (10.172.26.151) by
    BLUPR17MB0193.namprd17.prod.outlook.com (10.162.234.20) with Microsoft SMTP
    15.20.77.7; Mon, 2 Oct 2017 11:02:16 +0000
    Received: from CO1NAM04FT056.eop-NAM04.prod.protection.outlook.com
    (2a01:111:f400:7e4d::203) by BN6PR1701CA0013.outlook.office365.com
    (2603:10b6:405:15::23) with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P256) id 15.20.56.11 via
    Frontend Transport; Mon, 2 Oct 2017 11:02:16 +0000
    CO1NAM04FT056.mail.protection.outlook.com (10.152.91.198) with Microsoft SMTP
    15.20.56.11 via Frontend Transport; Mon, 2 Oct 2017 11:02:15 +0000
    Received: from NAM02-BL2-obe.outbound.protection.outlook.com (207.46.163.79) by us-emailsignatures-cloud.codetwo.com with CodeTwo SMTP Server (TLS) via SMTP; Mon, 02 Oct 2017 11:02:13 +0000
    BY2PR17MB0280.namprd17.prod.outlook.com (10.163.67.146) with Microsoft SMTP
    15.20.77.7; Mon, 2 Oct 2017 11:02:10 +0000
    15.20.0077.018; Mon, 2 Oct 2017 11:02:10 +0000
    Thread-Index: AQHTOXSUYEkvvlbluUSlt+iTHzohN6LNkboAgABmjYCAASg9gIAAP20AgAARewCAACvNKIAAErWAgAAfBwCAAJnstw==
    Date: Mon, 2 Oct 2017 11:02:10 +0000
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    X-MS-Has-Attach:
    [email protected];
    X-Microsoft-Exchange-Diagnostics-untrusted: 1;BY2PR17MB0280;20:0EHpER5RYz4oMVILBKpMZY8TmF9rQpJX6fjT35fit9t4bf79wFOv0EMXYuZEIz4a1+VsbIVXpJGJ4c+Ykruwy38UAq4qR226aP0ChAc+478ZGstTDSl857+ZlXvJWM3KbhdwTUjLe/A/GMNr5NH/byKaimWQhmyZlOzXwWaVCAY=
    X-MS-Office365-Filtering-Correlation-Id: 4ba815d9-51a0-4ea8-cc4b-08d509850a8c
    X-Microsoft-Antispam-Untrusted: UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:BY2PR17MB0280;
    X-MS-TrafficTypeDiagnostic: BY2PR17MB0280:|BLUPR17MB0193:
    UriScan:(131327999870524);UriScan:(131327999870524);
    =?us-ascii?Q?)(8121501046)(5005006)(3002001)(10201501046)(100000703101)(1?=
    =?us-ascii?Q?00105400095)(93006095)(6041248)(20161123555025)(201611235600?=
    =?us-ascii?Q?25)(20161123558100)(201703131423075)(201702281528075)(201703?=
    =?us-ascii?Q?061421075)(201703061406153)(20161123564025)(20161123562025)(?=
    =?us-ascii?Q?705101)(100105500095);SRVR:BY2PR17MB0280;BCL:0;PCL:0;RULEID:?=
    =?us-ascii?Q?7MB0280;BCL:0;PCL:0;RULEID:(100000700101)(100105000095)(1000?=
    =?us-ascii?Q?(2401047)(5005006)(8121501046)(10201501046)(100000703101)(10?=
    =?us-ascii?Q?0105400095)(3002001)(93006095)(93004095)(6041248)(2016112356?=
    =?us-ascii?Q?4025)(20161123560025)(20161123555025)(201703131423075)(20170?=
    =?us-ascii?Q?2281528075)(201703061421075)(201703061406153)(20161123562025?=
    =?us-ascii?Q?)(20161123558100)(6072148)(201708071742011)(100000704101)(10?=
    =?us-ascii?Q?0105200095)(100000705101)(100105500095);SRVR:BLUPR17MB0193;B?=
    =?us-ascii?Q?00095);SRVR:BLUPR17MB0193;?=
    x-forefront-prvs: 0448A97BF2
    X-Forefront-Antispam-Report-Untrusted: SFV:NSPM;SFS:(10009020)(376002)(346002)(39830400002)(377454003)(189002)(24454002)(199003)(2900100001)(36756003)(478600001)(86362001)(6506006)(6246003)(6436002)(6512007)(6306002)(99286003)(54896002)(53936002)(33656002)(2950100002)(82746002)(93886005)(236005)(50986999)(2906002)(8676002)(54356999)(81156014)(81166006)(77096006)(101416001)(6486002)(76176999)(229853002)(10126004)(6116002)(102836003)(53546010)(606006)(3846002)(66066001)(97736004)(25786009)(189998001)(68736007)(14971765001)(316002)(106356001)(3280700002)(72206003)(5660300001)(7736002)(7066003)(105586002)(966005)(8936002)(83716003)(14454004)(3660700001);DIR:OUT;SFP:1101;SCL:1;SRVR:BY2PR17MB0280;H:BY2PR17MB0277.namprd17.prod.outlook.com;FPR:;SPF:None;PTR:InfoNoRecords;MX:1;A:1;LANG:en;
    boundary=”_000_143F8C47D0FA4917B36153E93580898Fpapedawsoncom_”
    MIME-Version: 1.0
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BY2PR17MB0280
    X-CodeTwo-MessageID: 20171002110213.bf9b41c3-bd7c-40c3-bcb6-86e7f7bb0007@us-emailsignatures-cloud.codetwo.com
    X-MS-Exchange-Transport-CrossTenantHeadersStripped: CO1NAM04FT056.eop-NAM04.prod.protection.outlook.com
    CIP:23.96.243.78;IPV:NLI;CTRY:;EFV:NLI;SFV:NSPM;SFS:(10009020)(346002)(376002)(39830400002)(2970300002)(438002)(24454002)(199003)(189002)(377454003)(5660300001)(7066003)(4546004)(36756003)(8676002)(189998001)(106002)(966005)(606006)(93886005)(25786009)(83716003)(72206003)(53546010)(86362001)(575784001)(478600001)(2900100001)(316002)(16586007)(14971765001)(14454004)(50986999)(76176999)(54356999)(84326002)(10126004)(33656002)(236005)(2950100002)(6512007)(6486002)(6506006)(77096006)(54896002)(6306002)(106466001)(6116002)(102836003)(3846002)(2906002)(229853002)(512874002)(30436002)(66066001)(82746002)(8936002)(6246003)(99286003)(246002)(7596002)(7736002)(7636002)(356003);DIR:OUT;SFP:1101;SCL:1;SRVR:BLUPR17MB0193;H:us-emailsignatures-cloud.codetwo.com;FPR:;SPF:Pass;PTR:us-emailsignatures-cloud.codetwo.com;A:1;MX:3;LANG:en;
    X-Microsoft-Exchange-Diagnostics: 1;CO1NAM04FT056;1:4a9/3mwp35O9Mt863Hd3+T9lqLsx8+9Bd2I8Vb3pfyfZ2luaX3NQpgBCPq9zsBqUkAS35OG81bkL6I1No1PDjvyJ7cjsBBDAob8zdAmQTxLN+/uYovQ4EC5D/P99qGh7
    UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(8251501002)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:BLUPR17MB0193;
    1;BLUPR17MB0193;3:Zyjvdv8OsmKU0qPpijMzxILkb5sLhiyYQK0/GY7rETBiuPxKIV0guKlro1AraHf/5cNAJoBCwEaXcmdM8scv4efZfivjNFWPs4JeGrtmy1z5d2KNVtBMqxtR4M/gb9Nkfu+MuF8xirqeZYjelESI0g24uX743LLQXn/1l0bUYa4S376AbEG6+RPkjSt/gQGDeEItHwG66pJFuoTBLLd88A9XgJkVzxlSYp/4lCPG2na2xpz1KRXSYo8FesZb5PrBwoHHUF2snMt70P9UlEaIqq4o0NoFOeSMcsaqYYZ54jZ10X+Rr/QdunVwHpHL0/ZWMBMhJkMwHHcTrw/JLsooig==;25:3FWCqj3Xh1mgtb3Tgu4/locZEzUxxGBIKZqIITSXYDFX08buBgbrITKdC/86BF+TzDQsZQ/cD0rNM4XM7R1Rs90pJ/y6uPjFD3Y1LNPjdGoE+Zfh/Jz7JdJ8DJYUDK5PZtuU/WpwiVEzCzz6NW8ij2QvKz64jMIQ4KXbU2VEhzZxeAilYpati/fWdum0pHebQ/jsgUyrAO6ea611OTEWNw2hCBwSTDpBxdkOrQiZbbv3aNPXjyKUlJxODIQqN0XNR5+WfnodZKENBMu5rcg8P3K1SOKAqVdygkx2cE0pIq63b3jUuCLgPjBUPvUnXa1KhJJqA/g0Az912HbFUXLACw==;31:CMYOBUuKS7lczE8WXNLwYyykNdXh1y1podCJY2d/WpeTRIUl5aU0iumN0wjUkMuw8aNuPk5xDjkFcAneqOindLV0CoKQESEUbKpyndk/lbAOWw/ZtvezJkCGG4b5atb8tR55W95vPQ4A9+R3YERVsX67JaQAl8jjlqkAhRhLy7VQ25NLHqtwKoCrA3hPKrOTygVvkOwQilFZ3vuf3KDUTLaNoc2we6Z3qxUaffHP9L4=
    1;BLUPR17MB0193;20: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;4:37MCwUA8GS231ePHOEUY0PfBUEwvX8HxIU8d/R3ECC10HpZNstKtc0W0u7Wr6+O6NuSgDXV9YEi4aQyID5Bht2J9QEJctVGepRmNunQKdAs2hekrgW6Z5enyDD9vXXKIDdb7Bqkkkt4So31/GWLgLnONnxRLclSMIupAEn3Yplls1CLJxpdeEW+Oz0jSt7AamRjZ7A7keaHYqt9hbUHVznUbn5oQtJNHKqTRqavoyUKeSHJdVpzVnjfrwxZiHjwCtdIgX/fS6fBw5zxWyMHShC9jXX54a4KZHVd4/e0oPqA=
    X-Forefront-PRVS: 0448A97BF2
    =?us-ascii?Q?1;BLUPR17MB0193;23:7VuvBqbIwONv3VW7/isrvWLvSoiTV1LCtU9qu5Vnz?=
    =?us-ascii?Q?W13/AekgAcAqPk7T9a0tEtKADUcW37pwdmLI9SqKKJqGQwbejWVA1ASrahFZ?=
    =?us-ascii?Q?I9aOTl5TZd/BIsYUriZbul8zu12D7+yn96bya3agtTZiNw8K/tGycPOPzLxD?=
    =?us-ascii?Q?g/4zYBsRtn9rPm2yeBxRMka33c7/emN07PGl9VPdj4pSe6vt+rbOLrbM8Qi9?=
    =?us-ascii?Q?a8/g//9c3frPx4nrTyZwBq27mpEfMcIKkbiC7A+l1t7Mnn001HtnBxmu0o0/?=
    =?us-ascii?Q?g29BVoXqA+Og2T3IWK+Qt5EFJdRQvnIBE3DcJLk7HNmhYetDaxHjjseCSCRK?=
    =?us-ascii?Q?vP2t0qPyPwkivYjl/4cxmkRvBsawwH7HZCzC4AL645XbFCaEzQTBYOAPoCdL?=
    =?us-ascii?Q?JhNRtqbCwLn8YTOjY7j3Q2OMcI+YudekqPBTBlEX5rOwok1rBu/XplcqFqNm?=
    =?us-ascii?Q?hmD6Mj6LQ36K5et0EDb2pCKaHrEhUeieR06hvWE6SqBfFueExVjbsqj58bUk?=
    =?us-ascii?Q?IMD7JMJa8PspZssFr5NGWG5o6O08NaxdzdyvsvwKwPGVDHIpy+gcBHlIUP59?=
    =?us-ascii?Q?ohL/nUhRqrRYRDJ9Xy+7l/SbylMuICTu1VoPYBZMP7CRozdT2wndagY4OjWg?=
    =?us-ascii?Q?mzttabs1nN9ZXIDkrZGgFQ1Eg0KEMJPiRMVa2qQiVcKTr0xIiyMfVuiiGTUR?=
    =?us-ascii?Q?XL7FSsM4cdWddvXIGUKUZzmLL6He55R7bfYhJcLmd94mylp9XGOJnjRF3PJh?=
    =?us-ascii?Q?lnTQ2CX3lYFebv5QMqOvinxbBg3RtF7OlwyjLQ5RA7dnpb23vgTCHYspBdos?=
    =?us-ascii?Q?MvL0b2ubMHmVOoZfdXpxd+oJIIhR7sFihm8k/E/rmBBMD0zSRLwbOuGp2HB1?=
    =?us-ascii?Q?dOqJYBkhYQ0/KZgD3XqAx8SU0I236JblBfg7/6QXu+cw1TNkn9j/O2sYGD/J?=
    =?us-ascii?Q?hq9oigET5Ak/C5MF/ALLvIQTOM5HE72zfwQX/opGxZn/l96lRX0NINPy0guy?=
    =?us-ascii?Q?1AXS/juhSCoQVPsN/te2HI6Iwl6684IaGp3nFTFA1P4tnDRa//Y0BLDwWukp?=
    =?us-ascii?Q?Q2yc2yOjzGEBHctzzeyGKwmMgjksCO5VGjXxEkw/XOm3NDy+2YgPx1+MPwCl?=
    =?us-ascii?Q?IYNV5ZxENeMxQIQbq3Bi2Jz3GySTKr+t1eCiUv1ad+jXEKUlU+t2kDtbcxhx?=
    =?us-ascii?Q?DO4ocW89y37IFYniYeLHvLKWbN8CfV7faPvGkNtTU0sXxxhr86LdDorccmC6?=
    =?us-ascii?Q?yG7B7bPWis4m7WxYC5eFTggfuLxpQlngWGp58quvhMClZf1ipszWHoddJsTS?=
    =?us-ascii?Q?7YnIzRFheE/Oa/SesDsptyAzLdOmDa5SX1SchkMMBBmESxmJ2J7eX4Qco0qY?=
    =?us-ascii?Q?crOU1PxhApBOuiqZ7Q4vFE5XBTBL8pK7RXFMROZoizbELZEUKP+mBLvE5fd2?=
    =?us-ascii?Q?wJ/V4Tumg=3D=3D?=
    1;BLUPR17MB0193;6:fNAqZZckZzK00FpOZPZie5HVVWwGHOXlGJpg/o5+UFizCxhfmOywJsm1zMpv/uKNq+YTo4VopgLplxA14cIMWgcPhl8pWWI3CF7Fa8eP0feHZGkNcCCMKdK2LQX8R9x6d1faFBl5k7dSGjlijPpFMHjL05cHte60SG9TTM+Vi+PuybDpkrFpoCvGajDuISQpyLmuKo1gwNMZ1ZZAivfFfw1FHj3djAu10F8+nRA7XSRLN/0Ws81DtQD4KZpOsrEWxyHtLdyoPUB+zBVALP83ll+FwrpRi5AeeEHoKiKmOvcqvHv9hmU5mFYI4eSe7mT9Pl2qhkBaVhfOgxLQOClDGQ==;5:CS0YzK4vobdixeE1RmKzoOsaROQArZ20ZREougu7hn2JUpsLXUf92xe5XBDpB423CnSvWjzXyPkF1waXfgGQL3wv9uchULyIISqGarlIh2dPIUgKaoadbHgsD7HNB0SuN263wE7MprYWZ5tAv0WmWA==;24:jsWVXz1eNHi3QV/7YG9H0eCzfzAb9WEN31WYkmZcxN2jUT6U43NhcaJ51UdNhCOdPromwQEWkTIi0NUfPQt4EM7XM806nH4hKVbrIMFC31U=;7:BboSSNrBn2ryPhfZHjzbAny8BvPqvWNHf6d1BuqzYxJ6ZekPjbkLBgmhvAj0sEnkLefv7fxgKGBWRR1CrXEzv9djzJiMaUIYKWZw/lKpxGsCf66ETao61xH/gDqos9zQHEUk8rbiuDSHOCzJzL50/hcmPDjg64GPAmx8Jq1uDZzqznAakfEEpry+JQhR/k91w3IAfYWUOgFyR3AkNiEDtqwyIZnSEUhW6ldRjutTjto=
    1;BLUPR17MB0193;20:PDCE4jPTp56fraVW/ypI2i4FKmmxJhwvTTdolImAwlGfuyaJe8eDjPdl6Xkj81tmic2Vv+En08Blwaf1wEsesjjgqlE2Y3X/6aKpwo5KrsDb+kzc4I6n7D7SMcOgsZxK4bxH4aas34pvtSChqAhlAFW856OJu3PKkKKwc0++mWc=
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 02 Oct 2017 11:02:15.3686
    (UTC)
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BLUPR17MB0193
    –_000_143F8C47D0FA4917B36153E93580898Fpapedawsoncom_
    V2hhdCBpcyB5b3VyIHRvdGFsIGFyZWEgYW5kIHRvdGFsIG51bWJlciBvZiBjZWxscz8gQXJjR2lz
    IGNhbiBoYW5kbGUgYSBsb3QgYnV0IGl0IHdpbGwgYmUgbGltaXRlZCBieSB5b3VyIGNvbXB1dGVy
    LiBXaGF0IGFyZSB5b3VyIGNvbXB1dGVyIHNwZWNpZmljYXRpb25zPw0KDQoNCkxlZSB2b24gR3lu
    ei1HdWV0aGxlLCBQLkUuIHwgUHJvamVjdCBFbmdpbmVlcg0KUGFwZS1EYXdzb24gRW5naW5lZXJz
    LCBJbmMuDQpUQlBFIEZpcm0gUmVnaXN0cmF0aW9uICM0NzAgfCBUQlBMUyBGaXJtIFJlZ2lzdHJh
    dGlvbiAjMTAxOTM5NzQNCg0KMTAzMzMgUmljaG1vbmQgQXZlLiwgU3VpdGUgOTAwLCBIb3VzdG9u
    LCBUWCA3NzA0Mg0KUDogNzEzLTQyOC0yNDAwIHwgRTogTHZvbkd5bnotR3VldGhsZUBwYXBlLWRh
    d3Nvbi5jb20gfCB2Y2FyZDxmdHA6Ly92Y2FyZDpwRF8yMDAwQGZ0cC5wYXBlLWRhd3Nvbi5jb20v
    TGVlJTIwdm9uJTIwR3luei1HdWV0aGxlLnZjZj4NCg0KSG91c3RvbiB8IFNhbiBBbnRvbmlvIHwg
    QXVzdGluIHwgRm9ydCBXb3J0aCB8IERhbGxhcw0KDQpDT05GSURFTlRJQUxJVFkgTk9USUNFDQpU
    aGlzIGVsZWN0cm9uaWMgbWFpbCB0cmFuc21pc3Npb24gbWF5IGJlIGNvbmZpZGVudGlhbCwgbWF5
    IGJlIHByaXZpbGVnZWQsIGFuZCBzaG91bGQgYmUgcmVhZCBvciByZXRhaW5lZCBvbmx5IGJ5IHRo
    ZSBpbnRlbmRlZCByZWNpcGllbnQuDQpJZiB5b3UgaGF2ZSByZWNlaXZlZCB0aGlzIHRyYW5zbWlz
    c2lvbiBpbiBlcnJvciwgcGxlYXNlIGltbWVkaWF0ZWx5IG5vdGlmeSB0aGUgc2VuZGVyIGFuZCBk
    ZWxldGUgaXQgZnJvbSB5b3VyIHN5c3RlbS4NCg0KT24gT2N0IDEsIDIwMTcsIGF0IDg6NTEgUE0s
    IGNhbWVyb24gW3ZpYSBIRUMtUkFTIEhlbHBdIDxtbCtzMTA5MTExMm40NTYwaDk3QG41Lm5hYmJs
    ZS5jb208bWFpbHRvOm1sK3MxMDkxMTEybjQ1NjBoOTdAbjUubmFiYmxlLmNvbT4+IHdyb3RlOg0K
    DQpXaGF0IGFyZSB5b3UgbW9kZWxpbmcgdGhhdCByZXF1aXJlcyBsZXNzIHRoYW4gMWZ0IGVsZW1l
    bnRzPw0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KSWYgeW91IHJlcGx5IHRv
    IHRoaXMgZW1haWwsIHlvdXIgbWVzc2FnZSB3aWxsIGJlIGFkZGVkIHRvIHRoZSBkaXNjdXNzaW9u
    IGJlbG93Og0KaHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20veC1hbmQt
    eS1jby1vcmRpbmF0ZXMtb2Ytc2hlYXItc3RyZXNzLXRwNDU0NXA0NTYwLmh0bWwNClRvIHVuc3Vi
    c2NyaWJlIGZyb20geCBhbmQgeSBjby1vcmRpbmF0ZXMgb2Ygc2hlYXIgc3RyZXNzLCBjbGljayBo
    ZXJlPGh0dHA6Ly9oZWMtcmFzLWhlbHAuMTA5MTExMi5uNS5uYWJibGUuY29tL3RlbXBsYXRlL05h
    bWxTZXJ2bGV0Lmp0cD9tYWNybz11bnN1YnNjcmliZV9ieV9jb2RlJm5vZGU9NDU0NSZjb2RlPWJI
    WnZibWQ1Ym5vdFozVmxkR2hzWlVCd1lYQmxMV1JoZDNOdmJpNWpiMjE4TkRVME5Yd3RNVEk1TWpr
    Mk1ESXhNZz09Pi4NCk5BTUw8aHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5j
    b20vdGVtcGxhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPW1hY3JvX3ZpZXdlciZpZD1pbnN0YW50
    X2h0bWwlMjFuYWJibGUlM0FlbWFpbC5uYW1sJmJhc2U9bmFiYmxlLm5hbWwubmFtZXNwYWNlcy5C
    YXNpY05hbWVzcGFjZS1uYWJibGUudmlldy53ZWIudGVtcGxhdGUuTmFiYmxlTmFtZXNwYWNlLW5h
    YmJsZS52aWV3LndlYi50ZW1wbGF0ZS5Ob2RlTmFtZXNwYWNlJmJyZWFkY3J1bWJzPW5vdGlmeV9z
    dWJzY3JpYmVycyUyMW5hYmJsZSUzQWVtYWlsLm5hbWwtaW5zdGFudF9lbWFpbHMlMjFuYWJibGUl
    M0FlbWFpbC5uYW1sLXNlbmRfaW5zdGFudF9lbWFpbCUyMW5hYmJsZSUzQWVtYWlsLm5hbWw+DQo=
    ZGl2PjwvZGl2Pg0KPGRpdj5XaGF0IGlzIHlvdXIgdG90YWwgYXJlYSBhbmQgdG90YWwgbnVtYmVy
    IG9mIGNlbGxzPyBBcmNHaXMgY2FuIGhhbmRsZSBhIGxvdCBidXQgaXQgd2lsbCBiZSBsaW1pdGVk
    IGJ5IHlvdXIgY29tcHV0ZXIuIFdoYXQgYXJlIHlvdXIgY29tcHV0ZXIgc3BlY2lmaWNhdGlvbnM/
    PC9kaXY+DQo8ZGl2Pjxicj4NCgo8UCBzdHlsZT0iRk9OVC1TSVpFOiA5cHQ7IEZPTlQtRkFNSUxZ
    OiBWZXJkYW5hIj48L1A+CjxQIHN0eWxlPSJGT05ULVNJWkU6IDlwdDsgRk9OVC1GQU1JTFk6IFZl
    cmRhbmEiPjxTUEFOIApzdHlsZT0iRk9OVC1GQU1JTFk6IFZlcmRhbmEiPjxTVFJPTkc+PFNQQU4g
    c3R5bGU9IkZPTlQtU0laRTogMTAuNXB0Ij5MZWUgdm9uIEd5bnotR3VldGhsZSwgUC5FLjwvU1BB
    Tj48L1NUUk9ORz4gPFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDEwcHQ7IENPTE9SOiAjNjY2NjY2
    Ij58IDxTVFJPTkc+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDlwdCI+UHJvamVjdCBFbmdpbmVl
    cjwvU1BBTj48L1NUUk9ORz48L1NQQU4+PC9TUEFOPjxCUj48U1BBTiAKc3R5bGU9IkZPTlQtU0la
    RTogOXB0OyBGT05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDlw
    dDsgQ09MT1I6ICM2NjY2NjYiPjxTVFJPTkc+UGFwZS1EYXdzb24gRW5naW5lZXJzLCAKSW5jLjwv
    U1RST05HPjwvU1BBTj48L1NQQU4+PEJSPjxTUEFOIHN0eWxlPSJGT05ULVNJWkU6IDlwdCI+PFNQ
    QU4gCnN0eWxlPSJDT0xPUjogIzY2NjY2NiI+PFNQQU4gc3R5bGU9IkZPTlQtU0laRTogOXB0OyBG
    T05ULUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDlwdCI+VEJQRSBG
    aXJtIFJlZ2lzdHJhdGlvbiAjNDcwIHwgVEJQTFMgRmlybSBSZWdpc3RyYXRpb24gCiMxMDE5Mzk3
    NDwvU1BBTj48L1NQQU4+PC9TUEFOPjwvU1BBTj48L1A+CjxQIHN0eWxlPSJGT05ULVNJWkU6IDlw
    dDsgRk9OVC1GQU1JTFk6IFZlcmRhbmEiPjxTUEFOIApzdHlsZT0iRk9OVC1TSVpFOiA5cHQ7IEZP
    TlQtRkFNSUxZOiBWZXJkYW5hOyBDT0xPUjogIzAwMDAwMCI+PFNQQU4gCnN0eWxlPSJGT05ULVNJ
    WkU6IDlwdDsgRk9OVC1GQU1JTFk6IFZlcmRhbmE7IENPTE9SOiAjNjY2NjY2Ij4xMDMzMyBSaWNo
    bW9uZCAKQXZlLiwgU3VpdGUgOTAwLCBIb3VzdG9uLCBUWCA3NzA0MiA8L1NQQU4+PC9TUEFOPjxC
    Uj48U1BBTiAKc3R5bGU9IkZPTlQtRkFNSUxZOiBWZXJkYW5hOyBDT0xPUjogIzY2NjY2NiI+PFNQ
    QU4gCnN0eWxlPSJGT05ULVNJWkU6IDlwdCI+PFNUUk9ORz48U1BBTiAKc3R5bGU9IkNPTE9SOiAj
    MDAwMDAwIj5QOjwvU1BBTj48L1NUUk9ORz4mbmJzcDs3MTMtNDI4LTI0MDAmbmJzcDt8IDxTVFJP
    Tkc+PFNQQU4gCnN0eWxlPSJDT0xPUjogIzAwMDAwMCI+RTo8L1NQQU4+PC9TVFJPTkc+IEx2b25H
    eW56LUd1ZXRobGVAcGFwZS1kYXdzb24uY29tIHwgPEEgCnN0eWxlPSJURVhULURFQ09SQVRJT046
    IG5vbmU7IENPTE9SOiAjNjY2NjY2IiAKaHJlZj0iZnRwOi8vdmNhcmQ6cERfMjAwMEBmdHAucGFw
    ZS1kYXdzb24uY29tL0xlZSB2b24gR3luei1HdWV0aGxlLnZjZiI+PFNUUk9ORz52Y2FyZDwvU1RS
    T05HPjwvQT48L1NQQU4+PC9TUEFOPjwvUD4KPFAgc3R5bGU9IkZPTlQtU0laRTogOXB0OyBGT05U
    LUZBTUlMWTogVmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULUZBTUlMWTogVmVyZGFuYTsgQ09M
    T1I6ICM2NjY2NjYiPjxTUEFOIApzdHlsZT0iRk9OVC1TSVpFOiA5cHQiPjxTVFJPTkc+SG91c3Rv
    biB8IFNhbiBBbnRvbmlvIHwgQXVzdGluIHwgRm9ydCBXb3J0aCB8IApEYWxsYXM8L1NUUk9ORz48
    L1NQQU4+PC9TUEFOPjwvUD4KPFAgc3R5bGU9IkZPTlQtU0laRTogOXB0OyBGT05ULUZBTUlMWTog
    VmVyZGFuYSI+PFNQQU4gCnN0eWxlPSJGT05ULVNJWkU6IDdwdDsgRk9OVC1GQU1JTFk6IFZlcmRh
    bmE7IENPTE9SOiAjNjY2NjY2OyBMSU5FLUhFSUdIVDogMTJwdCI+PEVNPjxTUEFOIApzdHlsZT0i
    Rk9OVC1TSVpFOiA3LjVwdCI+Q09ORklERU5USUFMSVRZIE5PVElDRTxCUj5UaGlzIGVsZWN0cm9u
    aWMgbWFpbCAKdHJhbnNtaXNzaW9uIG1heSBiZSBjb25maWRlbnRpYWwsIG1heSBiZSBwcml2aWxl
    Z2VkLCBhbmQgc2hvdWxkIGJlIHJlYWQgb3IgCnJldGFpbmVkIG9ubHkgYnkgdGhlIGludGVuZGVk
    IHJlY2lwaWVudC48QlI+SWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhpcyAKdHJhbnNtaXNzaW9uIGlu
    IGVycm9yLCBwbGVhc2UgaW1tZWRpYXRlbHkgbm90aWZ5IHRoZSBzZW5kZXIgYW5kIGRlbGV0ZSBp
    dCBmcm9tIAp5b3VyIHN5c3RlbS48L1NQQU4+PC9FTT48L1NQQU4+PC9QPk9uIE9jdCAxLCAyMDE3
    LCBhdCA4OjUxIFBNLCBjYW1lcm9uIFt2aWEgSEVDLVJBUyBIZWxwXSAmbHQ7PGEgaHJlZj0ibWFp
    bHRvOm1sJiM0MztzMTA5MTExMm40NTYwaDk3QG41Lm5hYmJsZS5jb20iPm1sJiM0MztzMTA5MTEx
    Mm40NTYwaDk3QG41Lm5hYmJsZS5jb208L2E+Jmd0OyB3cm90ZTo8YnI+DQo8YnI+DQo8L2Rpdj4N
    CjxibG9ja3F1b3RlIHR5cGU9ImNpdGUiPg0KPGRpdj5XaGF0IGFyZSB5b3UgbW9kZWxpbmcgdGhh
    dCByZXF1aXJlcyBsZXNzIHRoYW4gMWZ0IGVsZW1lbnRzPyA8YnI+DQo8YnI+DQo8aHIgbm9zaGFk
    ZT0ibm9zaGFkZSIgc2l6ZT0iMSIgY29sb3I9IiNjY2NjY2MiPg0KPGRpdiBzdHlsZT0iY29sb3I6
    IzQ0NDsgZm9udDogMTJweCB0YWhvbWEsZ2VuZXZhLGhlbHZldGljYSxhcmlhbCxzYW5zLXNlcmlm
    OyI+DQo8ZGl2IHN0eWxlPSJmb250LXdlaWdodDpib2xkIj5JZiB5b3UgcmVwbHkgdG8gdGhpcyBl
    bWFpbCwgeW91ciBtZXNzYWdlIHdpbGwgYmUgYWRkZWQgdG8gdGhlIGRpc2N1c3Npb24gYmVsb3c6
    PC9kaXY+DQo8YSBocmVmPSJodHRwOi8vaGVjLXJhcy1oZWxwLjEwOTExMTIubjUubmFiYmxlLmNv
    bS94LWFuZC15LWNvLW9yZGluYXRlcy1vZi1zaGVhci1zdHJlc3MtdHA0NTQ1cDQ1NjAuaHRtbCI+
    aHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20veC1hbmQteS1jby1vcmRp
    bmF0ZXMtb2Ytc2hlYXItc3RyZXNzLXRwNDU0NXA0NTYwLmh0bWw8L2E+DQo8L2Rpdj4NCjxkaXYg
    c3R5bGU9ImNvbG9yOiM2NjY7IGZvbnQ6IDExcHggdGFob21hLGdlbmV2YSxoZWx2ZXRpY2EsYXJp
    YWwsc2Fucy1zZXJpZjttYXJnaW4tdG9wOi40ZW07bGluZS1oZWlnaHQ6MS41ZW0iPg0KVG8gdW5z
    dWJzY3JpYmUgZnJvbSB4IGFuZCB5IGNvLW9yZGluYXRlcyBvZiBzaGVhciBzdHJlc3MsIDxhIGhy
    ZWY9Imh0dHA6Ly9oZWMtcmFzLWhlbHAuMTA5MTExMi5uNS5uYWJibGUuY29tL3RlbXBsYXRlL05h
    bWxTZXJ2bGV0Lmp0cD9tYWNybz11bnN1YnNjcmliZV9ieV9jb2RlJmFtcDtub2RlPTQ1NDUmYW1w
    O2NvZGU9YkhadmJtZDVibm90WjNWbGRHaHNaVUJ3WVhCbExXUmhkM052Ymk1amIyMThORFUwTlh3
    dE1USTVNamsyTURJeE1nPT0iPg0KY2xpY2sgaGVyZTwvYT4uPGJyPg0KPGEgaHJlZj0iaHR0cDov
    L2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20vdGVtcGxhdGUvTmFtbFNlcnZsZXQu
    anRwP21hY3JvPW1hY3JvX3ZpZXdlciZhbXA7aWQ9aW5zdGFudF9odG1sJTIxbmFiYmxlJTNBZW1h
    aWwubmFtbCZhbXA7YmFzZT1uYWJibGUubmFtbC5uYW1lc3BhY2VzLkJhc2ljTmFtZXNwYWNlLW5h
    YmJsZS52aWV3LndlYi50ZW1wbGF0ZS5OYWJibGVOYW1lc3BhY2UtbmFiYmxlLnZpZXcud2ViLnRl
    bXBsYXRlLk5vZGVOYW1lc3BhY2UmYW1wO2JyZWFkY3J1bWJzPW5vdGlmeV9zdWJzY3JpYmVycyUy
    MW5hYmJsZSUzQWVtYWlsLm5hbWwtaW5zdGFudF9lbWFpbHMlMjFuYWJibGUlM0FlbWFpbC5uYW1s
    LXNlbmRfaW5zdGFudF9lbWFpbCUyMW5hYmJsZSUzQWVtYWlsLm5hbWwiIHJlbD0ibm9mb2xsb3ci
    IHN0eWxlPSJmb250OjlweCBzZXJpZiI+TkFNTDwvYT4NCjwvZGl2Pg0KPC9kaXY+DQo8L2Jsb2Nr
    cXVvdGU+DQo8L2JvZHk+DQo8L2h0bWw+DQo=
    –_000_143F8C47D0FA4917B36153E93580898Fpapedawsoncom_–
    #10914
    ldguethle
    Return-Path:
    Mon, 02 Oct 2017 08:18:46 -0400
    X-Cyrus-Session-Id: sloti25t09-1593747-1506946725-2-14761168075811682572
    X-Spam-score: 0.0
    RCVD_IN_MSPIKE_H3 -0.01, RCVD_IN_MSPIKE_WL -0.01, SPF_HELO_PASS -0.001,
    SA_VERSION 3.4.0
    X-Spam-source: IP=’104.47.33.55′,
    Host=’mail-bn3nam01on0055.outbound.protection.outlook.com’, Country=’US’,
    X-Spam-charsets: plain=’us-ascii’, html=’us-ascii’
    Received: from mx2 ([10.202.2.201])
    by compute1.internal (LMTPProxy); Mon, 02 Oct 2017 08:18:46 -0400
    Received: from mx2.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id 3B1A1D8622
    for ; Mon, 2 Oct 2017 08:18:45 -0400 (EDT)
    by mx2.messagingengine.com (Authentication Milter) with ESMTP
    id EC802E56E8D;
    Authentication-Results: mx2.messagingengine.com;
    dkim=pass (1024-bit rsa key sha256) header.d=papedawson.onmicrosoft.com [email protected] header.b=Qq/DamEQ;
    iprev=pass policy.iprev=104.47.33.55 (mail-bn3nam01on0055.outbound.protection.outlook.com);
    x-ptr=fail x-ptr-helo=NAM01-BN3-obe.outbound.protection.outlook.com x-ptr-lookup=mail-bn3nam01on0055.outbound.protection.outlook.com;
    Received-SPF: pass
    receiver=mx2.messagingengine.com;
    identity=mailfrom;
    client-ip=104.47.33.55
    Received: from NAM01-BN3-obe.outbound.protection.outlook.com (mail-bn3nam01on0055.outbound.protection.outlook.com [104.47.33.55])
    by mx2.messagingengine.com (Postfix) with ESMTPS
    for ; Mon, 2 Oct 2017 08:18:43 -0400 (EDT)
    bh=wE8psdu0ptZzEho+hJMm317Re/ysx9YdqZCmlcwWmPU=;
    b=Qq/DamEQme6f1KgpYimqr8Vi/Q4YLNh6MfdKue1/4M8rCp0EZVMOnOmcK9VAAOiS2sYAordZ1jIYilNPLEDttYSD64EPi3EBVS4fh6NiUg/mwb/HuihqYMvpwBIzGSW3IRgBOuEQHS2o5Cn8YkD7/Ax4m42+TsA/x7u3vlRA7RU=
    Received: from CY1PR17CA0011.namprd17.prod.outlook.com
    (2a01:111:e400:51db::21) by BY1PR17MB0120.namprd17.prod.outlook.com
    (2a01:111:e400:507c::16) with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P256) id 15.20.77.7; Mon, 2 Oct
    2017 12:18:40 +0000
    Received: from BN3NAM04FT012.eop-NAM04.prod.protection.outlook.com
    (2a01:111:f400:7e4e::207) by CY1PR17CA0011.outlook.office365.com
    (2a01:111:e400:51db::21) with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384) id 15.20.56.11 via Frontend
    Transport; Mon, 2 Oct 2017 12:18:39 +0000
    BN3NAM04FT012.mail.protection.outlook.com (10.152.92.169) with Microsoft SMTP
    15.20.56.11 via Frontend Transport; Mon, 2 Oct 2017 12:18:39 +0000
    Received: from NAM01-BN3-obe.outbound.protection.outlook.com (216.32.180.179) by us-emailsignatures-cloud.codetwo.com with CodeTwo SMTP Server (TLS) via SMTP; Mon, 02 Oct 2017 12:17:54 +0000
    BY2PR17MB0278.namprd17.prod.outlook.com (10.163.67.144) with Microsoft SMTP
    15.20.77.7; Mon, 2 Oct 2017 12:17:51 +0000
    15.20.0077.018; Mon, 2 Oct 2017 12:17:51 +0000
    Subject: RE: x and y co-ordinates of shear stress
    Thread-Index: AQHTOXSUYEkvvlbluUSlt+iTHzohN6LQfc1g
    Date: Mon, 2 Oct 2017 12:17:50 +0000
    Message-ID:
    <[email protected]>
    <[email protected]>
    X-MS-Has-Attach:
    [email protected];
    x-originating-ip: [199.227.135.86]
    X-Microsoft-Exchange-Diagnostics-untrusted: 1;BY2PR17MB0278;20:V1T+Wd59Yrj/D32otREbMq7kaEu8pp7Qpmznf6uI0eTJ1IKk/LDbGWQpImtOmMKeJ2IfepeyeZ1sTlFTBKSEtE972EczTyLrmJKC4iHCOGVz0fRLyrY40sp6yEMdKMWIk+m4pgG+ZmvHcL3Fqgmt5H1z9jDyINetdvLEVLHztBA=
    X-MS-Office365-Filtering-Correlation-Id: 39308f1f-909b-4b3d-d499-08d5098fb6c6
    X-Microsoft-Antispam-Untrusted: UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:BY2PR17MB0278;
    X-MS-TrafficTypeDiagnostic: BY2PR17MB0278:|BY1PR17MB0120:
    UriScan:(21748063052155);UriScan:(21748063052155);
    =?us-ascii?Q?)(5005006)(8121501046)(100000703101)(100105400095)(3002001)(?=
    =?us-ascii?Q?93006095)(10201501046)(6041248)(201703131423075)(20170228152?=
    =?us-ascii?Q?8075)(201703061421075)(201703061406153)(20161123564025)(2016?=
    =?us-ascii?Q?1123562025)(20161123558100)(20161123560025)(20161123555025)(?=
    =?us-ascii?Q?705101)(100105500095);SRVR:BY2PR17MB0278;BCL:0;PCL:0;RULEID:?=
    =?us-ascii?Q?7MB0278;BCL:0;PCL:0;RULEID:(100000700101)(100105000095)(1000?=
    =?us-ascii?Q?(2401047)(5005006)(8121501046)(100000703101)(100105400095)(3?=
    =?us-ascii?Q?002001)(93006095)(93004095)(10201501046)(6041248)(2017031314?=
    =?us-ascii?Q?161123558100)(20161123555025)(20161123562025)(20161123564025?=
    =?us-ascii?Q?)(20161123560025)(6072148)(201708071742011)(100000704101)(10?=
    =?us-ascii?Q?0105200095)(100000705101)(100105500095);SRVR:BY1PR17MB0120;B?=
    =?us-ascii?Q?00095);SRVR:BY1PR17MB0120;?=
    X-Forefront-Antispam-Report-Untrusted: SFV:NSPM;SFS:(10009020)(346002)(39830400002)(376002)(199003)(189002)(377454003)(66066001)(74316002)(86362001)(102836003)(6116002)(790700001)(3846002)(189998001)(7696004)(5660300001)(25786009)(316002)(6436002)(6246003)(8676002)(81166006)(81156014)(97736004)(10126004)(8936002)(14971765001)(229853002)(19609705001)(106356001)(105586002)(53936002)(6506006)(77096006)(2950100002)(54356999)(50986999)(68736007)(76176999)(53546010)(3660700001)(966005)(14454004)(72206003)(101416001)(3280700002)(2906002)(478600001)(2900100001)(7066003)(606006)(9686003)(55016002)(6306002)(54896002)(236005)(99286003)(33656002)(7736002);DIR:OUT;SFP:1101;SCL:1;SRVR:BY2PR17MB0278;H:BY2PR17MB0277.namprd17.prod.outlook.com;FPR:;SPF:None;PTR:InfoNoRecords;A:1;MX:1;LANG:en;
    boundary=”_000_BY2PR17MB027796EAE1ECE4006ABA7F01C27D0BY2PR17MB0277namp_”
    MIME-Version: 1.0
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BY2PR17MB0278
    X-CodeTwo-MessageID: 20171002121754.9eb6aa87-ade6-487e-806a-4b3dfd5bcd95@us-emailsignatures-cloud.codetwo.com
    X-MS-Exchange-Transport-CrossTenantHeadersStripped: BN3NAM04FT012.eop-NAM04.prod.protection.outlook.com
    CIP:23.96.243.78;IPV:NLI;CTRY:;EFV:NLI;SFV:NSPM;SFS:(10009020)(376002)(346002)(39830400002)(2980300002)(438002)(377454003)(199003)(189002)(25786009)(14454004)(102836003)(3846002)(6116002)(14971765001)(53546010)(316002)(8676002)(84326002)(16586007)(93886005)(7636002)(512954002)(7736002)(50986999)(7596002)(76176999)(54356999)(2906002)(229853002)(790700001)(189998001)(246002)(356003)(74316002)(106002)(8936002)(72206003)(478600001)(61614004)(5660300001)(7066003)(7696004)(6506006)(86362001)(66066001)(2900100001)(575784001)(2950100002)(77096006)(606006)(6306002)(33656002)(54896002)(236005)(9686003)(6246003)(10126004)(260700001)(106466001)(966005)(99286003)(55016002);DIR:OUT;SFP:1101;SCL:1;SRVR:BY1PR17MB0120;H:us-emailsignatures-cloud.codetwo.com;FPR:;SPF:Pass;PTR:us-emailsignatures-cloud.codetwo.com;A:1;MX:1;LANG:en;
    X-Microsoft-Exchange-Diagnostics: 1;BN3NAM04FT012;1:otS2bII/bxBJUrbMB+a06hM1KJMw+Pqux8+Fz49hLs/n8Gv8p0/iQDgoGQiRXiWXoFxdHg7unHyaHFs95Ic3as5XAccAkaYm5GT5RrtWICYGfcM/36EEku6chQcUi6wd
    UriScan:;BCL:0;PCL:0;RULEID:(22001)(2017030254152)(8251501002)(2017052603199)(201703131423075)(201703031133081)(201702281549075);SRVR:BY1PR17MB0120;
    1;BY1PR17MB0120;3:phwbLYluvn6hjRl+hrBqn64FyCvLNFxB48NriJ4DbfrBVA34XozsewF9Vj972Xms8qsjhvf739g92A59ZdyW9BxdUhTehJknit6xc3QWmPxcmPSV7mnKGjAAFEDAHvWA+2PIt71EdGcjsMJpGeifoMD/54aJ0wGZPu8mb+gl8Bk28P7q01PksOcG7I2Cirww6NSo1/+BMyoOkhAU+UGfjR3ZJGiRYiKX2x0cEibcarsAdTrOHDZqzaeTGblR9jQf8V37tuyF+tEph7AW2D0kiuALIph4eOmzMYSNel/CqAGRZmth5mDCI/0mew/FTQgdXf7xGJhFfiYdGgp6TDSNmQ==;25:ptpd4IcYngRhzWPzqMzgUq9J1dKvmE1U3+XVad3aSWNeWBPOJIo83dZuFEtIKCWIomlD1rHyoA7kNnPz+RLvEWf6HwDKvsEp2Zv7snhshTWrM3RL6Z5CkVThYM/rZL4MCsB9AzHIEV1fQJUBNN+U7R1X8anuvLVHb7M7NHAEuXQZZV7tHQzPasydcKgVhO3pk/bkM40KowbtqgULf8gWRkrVWDg0Ql7q+NLU0Ts/Ks9kLBjC17mvciRdhU/MHgQXG+yBn+3yH32pdzTjykXqL5a2/1G+LZBKtveXvluXoyjVnZ4mtRdxxjunvWU0nUFvK/03BoP2CojFvYNTEpRoe+kzHcMj4EvOqTTOPz9fNWI=
    1;BY1PR17MB0120;31:rQDLYp8T2fd5wlLIaGpWBEI9oj/tkuhl6owXI8QCV3aQZdmuuF6lAf/++qDatd4AiUkWebZOiC0EIvtqqRj9SO5UaTrF89J1engN6DrCXjc95OHGuSWCA6VNrdefQXdsWKQaohAPsWwzCGao1zXV87BW734uGScfM69Zfqt6CBAFJ7Xk6FVLCd2/RLx1Q6m05EfN7jzDwn6fIs7+pCQiWCaj3nRDNrmicdEClLBNlrI=;20: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
    1;BY1PR17MB0120;4:p+ApXxrhXvNNlbdML67mOrAGmRxm18vH56mhowRFsIRPK5B+pL4dAo/rcxh62e6uhUgrrANLsfA6v614NbAvWMmPYECmli4UH31zImtCisH+uqToIHyYQrDwsnTE9f/ngo02Hwokw9Cz6Ge7zC2TxlR7nh3dUqBkB1FVpufbZK5nwZ6OrMfP8krOO0mGp3UuHTpG/0rHy3gQqk14ZHM57pXRIPbzCw+o9oj9J+p0Dd+RUGKWIY6DnOhYJvdfU5GBC6lmPJyVPgOBLibLuYE+VvxpXNtOmrN4raWvXNIf76Q=
    =?us-ascii?Q?1;BY1PR17MB0120;23:2gtjCgPBJIxNGA2w6ycaZRpHioLF8qP99IWOhACLy?=
    =?us-ascii?Q?mYeV3fWBCYjEACvR8nDd6WLrje6/nerJRGhlqWW87HMg3vWO9caPpk00ue7X?=
    =?us-ascii?Q?cFaFnR7OHcMkJVsfl9ByK/G9jvVWnjsObucqp3ylyFoAd3RxliD+IF+6wt1T?=
    =?us-ascii?Q?AJiDmeTrx6kMHmH/rKvYTWEU8zGR62W0P2I4LZlMX4qyrNFmbeimrXHEjzXA?=
    =?us-ascii?Q?ilQV4V7wElDSddKpl1r8QLzolw+b+gqvIgIY0Ze6L7eD/fR+86NRgbe8B85e?=
    =?us-ascii?Q?fLL2Bnw9kB0SE8RpElwDJfEEb6Ietb5tDoeTfnHD1fHkADRqrYwUnOd98Ojw?=
    =?us-ascii?Q?VeN8rvimIztGNQWnEklK8j/fSmD/L6KcnfhkiZkiOLp46/EoguWP5NwqOFpM?=
    =?us-ascii?Q?+UvIwwQkI2X/fUawmfsxLwewymUKOmqgU96xF8MZGlCiviB5xir5/LmTg6Z/?=
    =?us-ascii?Q?BsB1G/9TIQUkKdpgR3dxHQNmpFcxAwdCp8BdwXZBTkdjJsfi57rF3KHdIPN6?=
    =?us-ascii?Q?8waJS0aL3fnNxjWUum/Ob10YiW8yyfaoVasFCnypE4hxyACWiQc4D1WzyJjS?=
    =?us-ascii?Q?2zJyizeHPe3G5L/K9So5AB7eUFf8eL9VGWkJCJwaIAVETUHIrdQOgXHf4QTb?=
    =?us-ascii?Q?TNIKwiEPe9/AKszV8E9Q1+CDNHJ1YYLqsChZFQbk9Jkg5WokgCLccTxPWC7T?=
    =?us-ascii?Q?jMstWVS6PTjC25YqD1c8C0nzHs7kPIc2Svwgx0v0IZ4HXfjoqcl8lVdgkxKK?=
    =?us-ascii?Q?Lymuqfg6+It7rv++bMoIe2X2kZ6RiNj/9fKaAE6M5YB8cNZt4Zg3606kYxHF?=
    =?us-ascii?Q?AoNGxd3IPgSlfQb9Ep1ZC7tWCReeYsvhQD7t/GzkdF5DtpEZtyJlWkSD2YM3?=
    =?us-ascii?Q?AdkXASxln0FphzzBadMSVuugQ+ImbEKvBo06ODSNMn+GkPczc8umV7c9Mqyw?=
    =?us-ascii?Q?oP16sf+O4cAHulOt7M/UY+zwhxFhhSPUXRmh3DyVwOBQSCdtfSwlOwNUZ23o?=
    =?us-ascii?Q?K/IKq7qs07GPvqANSdTm/+mIFuNl3T4aBT9LKFtW2ZUehS0WK+3CKqlEhNL+?=
    =?us-ascii?Q?/mViyRLFvCUqvlSLzTW1P131YTjW3EycoKo6RVSMQCiV63f5cHbmF2E8N6am?=
    =?us-ascii?Q?nqbCPb3KD3JFarVM8+FnmXmQ0qVBECxeh0pHa3P0Dn0X/Jft8wud0yAnx+r+?=
    =?us-ascii?Q?EQrcjiB7ob5QYMmbJNzt//zyr7Hz3IkjV/mmfCJIKacjmB60TqBMNVWMIKkt?=
    =?us-ascii?Q?/kS2xFgSP+r0LB931/bRduZrSqM3J5DAxdpCSQKZTnHEnJ22uazOw3fFqDLE?=
    =?us-ascii?Q?l142jWVDi7+n3daXCVvMuKwx1hmXoSXznSQ6397/3rLZd3oWMcFP6Aa33MwD?=
    =?us-ascii?Q?RQsEEwDPDvLr0uHoCZ1nj23kqkSSxYNUSjo5TDSKQL5puVs?=
    1;BY1PR17MB0120;6:e6QCnh3XgUzJxqkggCJcwDZXuqNfSyQiNHNqeNB5Pf70F+c9eiauCVgYyewvSOtRKGhI6moA786gBoLkg/4lPSXUw+GDL/UXk019EBCykhxC1iq/NFHWThsw92SqlmcSlW1D7eKV+8bleIj4hV+E0kmWA2p7Y6UTzyk9R3zSEX9bd0Y7mHUwP/xFHZZ3qO++dAyQjaXaDfdJnfotxiktYgxhAhnGS9R3sUp0/MnZODYE44aZV0gaNtRsfHyZsQ0zONwlaXK7uTYKVAmjPfki0jhzcPH9P9MBfbY4qIYLLbd4Gq+oBkmIGK8lRNZrkrguYnuv2YDNrxGagxD7HGS7tg==;5:+3RNpwfz2tNWHg7/ljqANZuUyGNkgwGHIS5EuhHlR1Iaz/lucoh2uQ8llEh+S0IjidNX55050K3a4VuYKVD7ihwAN0+3LpxqHpS+KfXGwPF494bO/wBYeW1gYDJCG3Gzb6DOW+nPI5bHjfPD8Trw/qqegPiGiPxm1mfF5lY/G8E=;24:1k1Evh6NK6UmB9qkAZPU6VYM1Q/kGC9Hp+SfjFvG4JxWck8WhpLl3xayez/DkGtaa34mUvBIH/VERYXF0Trg6vTk+Ss4j2F7nbWJyph9pdw=;7:fXvHN/HAQXNrCwJ2LZ+jA/L+n0UHz533iHYw5469EVD+7M/V4LSE9YmrjnEynwd8I+wAEEfTB4avPtwmfq4XsDSR4qITO7xHa+yqLNo/YrUnlkxsC5OoLEs/JC63vZucKaiEypLReJofHSUX4ljhQY/Pp7lOAOkXYIt+mu+s6vwb8GxT/rlMzrD6WqcXNGG/ehoUq7ts5ztSR23FP4ET12dzxO2XDTD7JURbaLoIj2s=
    1;BY1PR17MB0120;20:BgUWlS8CDMzPGH7ELwJzz/eNwbzsm7UY7s8QMyG8t6EF6OLfqNCVeHp1yW5zdeIkjY9bPhoMgSmoKDu99d+6lJ/L45EUEoTJjND0PmFm9ARGkiKNdn24gijtVc5z0jj0DtHVetVQty8Iyqxq4gdsg5gdd+ox2SJnrT+UEeAwXkk=
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 02 Oct 2017 12:18:39.3312
    (UTC)
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BY1PR17MB0120
    –_000_BY2PR17MB027796EAE1ECE4006ABA7F01C27D0BY2PR17MB0277namp_
    Was thinking about Flow Direction, which is not available.
    Lee von Gynz-Guethle, P.E. | Project Engineer
    Pape-Dawson Engineers, Inc.
    TBPE Firm Registration #470 | TBPLS Firm Registration #10193974
    10333 Richmond Ave., Suite 900, Houston, TX 77042
    P: 713-428-2400 | E: [email protected] | vcard<ftp://vcard:p=
    [email protected]/Lee%20von%20Gynz-Guethle.vcf>
    Houston | San Antonio | Austin | Fort Worth | Dallas
    CONFIDENTIALITY NOTICE
    This electronic mail transmission may be confidential, may be privileged, a=
    nd should be read or retained only by the intended recipient.
    If you have received this transmission in error, please immediately notify =
    the sender and delete it from your system.
    From: cameron [via HEC-RAS Help] [mailto:[email protected]]
    Sent: Friday, September 29, 2017 5:45 PM
    To: Lee von Gynz-Guethle @PD
    The velocity in x and y is an output option for HEC-RAS under the Output Op=
    low:
    http://hec-ras-help.1091112.n5.nabble.com/x-and-y-co-ordinates-of-shear-str=
    ess-tp4545p4552.html
    To unsubscribe from x and y co-ordinates of shear stress, click here.
    .view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%=
    3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabb=
    le%3Aemail.naml>
    Was thinking about Flow Direction, which is not avai=
    lable.
    =0A=
    =0A=
    Le=
    | Project Engineer
    Pape-Dawson Engineers, =0A=
    Inc.
    TBPE Firm Registration #470 | TBPLS Firm Registrat=
    ion =0A=
    #10193974
    =0A=
    10333 Richmo=
    nd =0A=
    P: 713-428-2400 | E: [email protected]=
    m | <= STRONG>vcard
    =0A=
    Houston | San Antonio | Austin | Fort Wort=
    h | =0A=
    Dallas
    =0A=
    This electronic mail =
    =0A=
    transmission may be confidential, may be privileged, and should be read or =
    =0A=
    If you have received this =0A=
    transmission in error, please immediately notify the sender and delete it f=
    rom =0A=
    your system.
    ron [via HEC-RAS Help] [mailto:ml+[email protected]]
    To: Lee von Gynz-Guethle @PD <[email protected]&gt=
    The velocity in x and=
    y is an output option for HEC-RAS under the Output Options so there is not=
    hing to do in HDF.
    If you reply to this email, your mes=
    sage will be added to the discussion below:
    http:/=
    /hec-ras-help.1091112.n5.nabble.com/x-and-y-co-ordinates-of-shear-stress-tp=
    4545p4552.html
    To unsubsc=
    click here
    NAML
    –_000_BY2PR17MB027796EAE1ECE4006ABA7F01C27D0BY2PR17MB0277namp_–
Viewing 15 posts - 1 through 15 (of 27 total)
