Welcome to the RAS Solution › Forums › HEC-RAS Help › WSE on steady flow doesn’t change on profile
When I run a steady flow analysis, my WSE becomes level and doesn’t change despite a descending profile.
After following many examples, my output doesn’t match what I find online. I feel like I am missing something simple.
I discovered that my alignment was created along “downstream” instead of along “upstream” in CAD. I was forcing water uphill which is why my WSE looked like a dam :]
How do you make your alignment downstream instead of upstream? I’m encountering the same issue currently.
you need to place your upstream boundary at the upstream end and not the downstream end.
Please enter an answer in digits:
