Welcome to the RAS Solution Forums HEC-RAS Help WSE is over height
  • This topic has 0 replies, 94 voices, and was last updated 7 years ago by DEL.
  • #7156
    DEL
    Hello every one..
    Any body can help for this problem, I used 1D-2D model for pump case. Before it, i have modeled case without storage area and pump. The model results was good. But when i add the storage area and pump for that’s model, the results is doesn’t make sense. The water surface on some of river segment is over height and sometimes modelling process was error.
    I have tried to make interpollation cross sections, increase the increment and points. But it doesn’t effect.
    Any suggestions for this? Thank You
