Welcome to the RAS Solution Forums HECRAS Controller Wrong outputs from GetWSELandVelocity code
  • This topic has 0 replies, 60 voices, and was last updated 6 years ago by Seb.
  • #8239
    Seb
    Good morning
    Sometimes when running the GetWSELandVelocity code from Chapter 3, after my computation is done, all RS cells are filled with +3.4003×10^38 (max range from single data type) instead of WSE and Vel results. Sometimes I get all my results, the macro works perfectly and it’s the same code, only with the *.prj link address being modified.
    So it’s obviously depending on the HECRAS project. Would anyone know why?
    Thank you and have a good day
