Welcome to the RAS Solution Forums HEC-RAS Help Wrong flow through Storage Area connection
  • This topic has 3 replies, 531 voices, and was last updated 11 years ago by Anonymous.
  • #5721
    I have a storage area connection connecting two storage areas. The connection is a combined weir and culvert. All the flow goes through the culvert, there is never flow over the weir.
    After running the model (unsteady) i compare the flow values reported in:
    1) Stage and flow hydrographs
    2) Storage area connection output. (Accessed by clicking the “View detailed output at XS, Culverts….” button in the main HEC-RAS window, and selecting Type = Storage Area Connection.
    For most SA connections the flow is the same (it should be). But for some SA connections the flow is completely different. Like + 50 % or – 50 %. The flow is equal for the first time steps but then the two results start gradually diverging. The HW and TW levels are the same in the
    I do compare the same time steps. There is no flow over the weir.
    Which, if any, of the outputs should I trust? The stage and flow hydrograph or the SA connection detailed output?
    Regards,
    Marulke
    #9159
    Lonnie A
    The storage area flow hydrographs are net inflow and won’t match the storage area connector. The net inflow is the flow from the storage area connector + any flow assigned directly to the storage area minus flow leaving the storage area.
    #9160
    Lonnie,
    this is not caused by a mix up between storage area and storage area connection.
    I have compared flows in several Storage Area Connections (not storage areas) by looking at:
    1) Stage and flow hydrographs for Storage Area Connection
    In my opinion the flow reported in 1 and 2 above should be equal. Mostly they are. But for some connections there are periods where 1 and 2 show significantly different flow (for the same time steps).
    Suggestions?
    #9161
    Lonnie A
    Marulke,
    I understand now what you were referring to. I looked at one of my older models I had available and also see differences between the DSS results and the table results. There were differences in both V4.1 and V5.0.
    Sorry I don’t have an answer as to why they are different. I’ll try and look into it some and if I find anything I’ll be sure to post back.
    Lonnie
