Welcome to the RAS Solution Forums HEC-RAS Help why ras mapper modifies the terrain
  • #15430
    mab aba
    hi, when I add a terrain in rasmapper (1m *1m resolution) I notice that rasmapper create triangles and the elevation values are differents inside my 1m cells of terrain used as input. Any help? thank you
    #15461
    alister.hood
    Yes, it seems to treat each cell value as the value at a point, and create a TRN joining up all those points, rather than treating the raster as 1mx1m flat surfaces separated by vertical walls.
    Does that help at all?
    I think it is debatable whether this way of considering the terrain is more correct, but it certainly allows for much nicer results – try resampling your raster to a finer grid (say to 0.1m x 0.1m), without interpolation, run a 2D model based on that, and you will see much uglier results. The main downside is that I think sometimes it causes difficulties with inputting levels of things that need to be above the level of the terrain (culverts and weirs).
