I want D*V data to flood damage analysis, But Depth Data at Cell Center and Velocity at Face point have 2 values each X Vel, Y Vel
Depth and Velocity, Both positions are different.
What should I do?
Lastly, I want export Depth map every 30 min. in 10 days : 10 x 24 x 2 = 480 maps, but RASMAPPER can export 1 by 1 map
for DV, you need to calculate the DV map by right clicking on the results layer and selecting “manage results map”. You can then select the DV for either a certain time or maximum value and then save the new DV map.
with regard to individual maps, it is the same process as above for depth but you need to do them one by one.
