Welcome to the RAS Solution › Forums › HECRAS Controller › where to find the controller in the HEC-RAS files?
- This topic has 3 replies, 467 voices, and was last updated 7 years, 6 months ago by Damienhua.
September 19, 2018 at 5:14 am #8221DamienhuaParticipant
i can not find the controller in my HEC-RAS installing files
i’ve search the internet but find that there are different expressions of the controller such as RAS50.HECRASCONTROLLER or HEC river analysis systemSeptember 19, 2018 at 5:27 am #13598DamienhuaParticipantis the ras.exe itself is the controller ,so we can import it directly?
September 19, 2018 at 8:16 am #13599Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.1.5-472-gf55f9be-fmstable-20180911v1) with LMTPA;
Wed, 19 Sep 2018 00:16:52 -0400
X-Cyrus-Session-Id: sloti1d2t14-154405-1537330612-2-5518157732577268676
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 1.3
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, MIME_QP_LONG_LINE 0.001,
RCVD_IN_DNSWL_NONE -0.0001, SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en,
BAYES_USED none, SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.210.173′, Host=’mail-pf1-f173.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Wed, 19 Sep 2018 00:16:52 -0400
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 68B934707F
for; Wed, 19 Sep 2018 00:16:51 -0400 (EDT)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id 07B1BC8555E;
1537330611; b=SAZWlUgliAqxykfw9zYYAoFhq/IDY1eL6wxiv+7rj19kGi+xuk
5OifMJhUx0wy5owfo1ZoypcPtSuqQQZCc28ikCzfnLOhPkVzKBp2G6vG2Y45P/yj
mhNLR8aKbXm19Oek4rzvICYlMNzVttbbEfY13i16+xq0qrHavUBg8y3gNej59Hmc
tGTG/E7GPDPC/mRRz9yo+VhliJMCzAsq3lFcN07sHuuEwpAC6hkhCuXD0e2c9nxX
IlYKsgJjxf39JC/rE2wOnNYG44V/b6B2IkPybNtKIfBz1LUogtyia24MmRRScMUz
SrmaiLtUaK6B5XXprnzqTuqHZNPw5VJT+ffg==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm3; t=1537330611; bh=KrHog9cNl5JX
4ZbydzTNAyvw3jTCoOle7zlBWO6dB3g=; b=az1VgsQtfE0T/X/G4CzBeOuzGxtx
RwYURtx41Hpho1DRiXtiUoTpU4a4UIVNMR+xh9A10WM8RrnB6RQlEY3RgdPP5qxv
VlkRtUCOZW8sVFLZyWk8ycx/TwfEDj9cpNEg7NW8oI84S6I7CODhU6oohPXWUTch
/ATwQuS348TKeQ5ALIKYkQv4i9IqrrTfJvsXyMSfId1wTB3vX+VQnRJnlLeQySg5
1THJPYkZWzEgvldzhxvTb9H9t4Z3PmrYXNZOqYbCMoRLGlVFCcsRdHZ81cam5dMy
kOvGnzMOYxkQ1S9A1BYKqaEkF6whhAp1TvgjpVn3QKUQrSehVlLsBceGaQ==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=ZWsAoda9 header.a=rsa-sha256
(p=none,sp=quarantine,d=none,d.eval=none) header.from=gmail.com;
iprev=pass policy.iprev=209.85.210.173 (mail-pf1-f173.google.com);
spf=pass [email protected]
smtp.helo=mail-pf1-f173.google.com;
x-cm=none score=0;
[email protected] header.b=pnWMINrj;
x-ptr=pass smtp.helo=mail-pf1-f173.google.com
policy.ptr=mail-pf1-f173.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx3.messagingengine.com;
x-cm=none score=0;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0x
MTg0JmNvZGU9ZEdobGNtRnpjMjlzZFhScGIyNUFaMjFoYVd3dVkyOXRmREV4T0RSOE1URT
NORGc1TkRneE5RPT0
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedtjedrkeejgdekfecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgenuceu
rghilhhouhhtmecufedttdenucenucfjughrpefhtgfgggffuffkfhgjvffosegrjehmre
hhtdejnecuhfhrohhmpefvhhgvucfttefuucfuohhluhhtihhonhcuoehthhgvrhgrshhs
ohhluhhtihhonhesghhmrghilhdrtghomheqnecuffhomhgrihhnpehnrggssghlvgdrtg
homhenucfkphepvddtledrkeehrddvuddtrddujeefpdejfedrfeejrdekgedrudduheen
ucfrrghrrghmpehinhgvthepvddtledrkeehrddvuddtrddujeefpdhhvghlohepmhgrih
hlqdhpfhduqdhfudejfedrghhoohhglhgvrdgtohhmpdhmrghilhhfrhhomhepoehthhgv
rhgrshhsohhluhhtihhonhesghhmrghilhdrtghomhequcfukfgkgfepiedvudegnecuve
hluhhsthgvrhfuihiivgeptd
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfC9rD3aAkfjT0KzZG9MffAg96m9xDggUIfZtbx8hGMMKskqIAxi9GadrtNSXARQaGtpYB1q9RxNRHJM/ocqOBlgaJ2qU9jIzvbKTUrobz3IyOrsg8PVa
ZjXbKOeopv/h1FbKv2Kuj9YV27LZiQy4/SKABRHZtY9GDEDAvfoOgxYx2LmLf8V2SRmY88upPqtF3aO8wSMgBgNR97GR6foiod2A6at95vaXMfuVkTFYj1Ie
X-CM-Analysis: v=2.3 cv=OZlJ8SbY c=1 sm=1 tr=0 a=i5xzRy8GnMa4EVhs8Gqg6w==:117
a=X4T1W4VCiokQfA7WB69biA==:17 a=x7bEGLp0ZPQA:10 a=po3G2Dre0K0A:10
a=JBFolyDoGHsA:10 a=9I5xiGouAAAA:8 a=UyCjLsv5jfFGukJJ7JoA:9 a=QEXdDO2ut3YA:10
a=lg4JEFhukzMA:10 a=4cVOsK3IpkcA:10 a=uWyLyLpbNcrBw27QgCAA:9
a=BEf3m_VPVD2x5CQL:21 a=_W_S_7VecoQA:10 a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=209.85.210.173
Received: from mail-pf1-f173.google.com (mail-pf1-f173.google.com [209.85.210.173])
by mx3.messagingengine.com (Postfix) with ESMTPS
for; Wed, 19 Sep 2018 00:16:50 -0400 (EDT)
Received: by mail-pf1-f173.google.com with SMTP id h69-v6so2053549pfd.4
for; Tue, 18 Sep 2018 21:16:50 -0700 (PDT)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=KrHog9cNl5JX4ZbydzTNAyvw3jTCoOle7zlBWO6dB3g=;
b=ZWsAoda9snKT9n0CJO+5rQBhbOKxdvRp6seMQqYn/RUjgmMjtFHTBGBkPoE1PXBih1
IjKUMlbT8PUOKJ5SCWxa08id+nXXOxYLPrj5rL392AmAkl2iW/WKEkSjP4So0aBvPGBT
Mmaa8GiZbPHb4XgCJ5tqAKrmvVVOQ3KMIQQh6jezmrg+Q7vN/RvwRLXOlra9eDtiaZV1
XCTomg2ZE2Ik+JhYAWOxhCtYEa8IN9ppNu9wYoLhFrQsqNDZ19M0PXV+ISz7ujPRX+xU
tXY7PfaHCYetiB2h0G2uNI0tAK10bvp8pZK3w+wTIMUb6aWozMF1tVbL7qijPK8fWRkI
iGeg==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=pnWMINrji4k5iXB4OvWe8kbabCMI1dyNJMrGaWyaPcCc3ROSSznJZl8T3TVIbTANzb
iC9m1NEt19lWGahx46UmeiupHgenhU1d+mNI9eGxVc7n2+li0WkgcBYI9nRjlZqIhJ89
7dQSFM0bdDLYDrqiqX+MfA7500J4Yn9/ORxYdK8n+AVw+uTkPIDJ3To5N9HG6BTONLh0
NGOqAbsrrUgILc0GlPd6y60R0A4kujNCPiaxQcNpN3qhPyyZIq9qN8OcPjUovFHVH2eN
tbuhu3GwmkVTJ3F1zWxI2brU4hwE0FjGr+Zl8mUMWBD5eH+oUHM2n/7ovLSniOedKwyd
fOwA==
X-Gm-Message-State: APzg51Bf/BdcnVB0vQ5PAP7t24MDT+VJOuS1ui8+zf0PAEf5p+A9vZja
wRvoA0haeaSzmnvubgmq1pAFj4L0
X-Google-Smtp-Source: ANB0VdZVEp6jjOTo+/ewhf41T55dZ5FhHge+7nxZEx2/uhO/aP1EodZnwQ3f/scQWRuExUpeMvUsOQ==
X-Received: by 2002:a63:7511:: with SMTP id q17-v6mr30891182pgc.144.1537330608560;
Tue, 18 Sep 2018 21:16:48 -0700 (PDT)
Received: from [192.168.1.14] (c-73-37-84-115.hsd1.or.comcast.net. [73.37.84.115])
by smtp.gmail.com with ESMTPSA id g6-v6sm27379430pgg.7.2018.09.18.21.16.47
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Tue, 18 Sep 2018 21:16:47 -0700 (PDT)
boundary=Apple-Mail-02B4A244-0F73-4861-908F-B7911C91C528
Mime-Version: 1.0 (1.0)
Date: Tue, 18 Sep 2018 21:16:46 -0700
Subject: Re: where to find the controller in the HEC-RAS files?
To: “Damienhua [via HEC-RAS Help]”
X-Mailer: iPhone Mail (15G77)–Apple-Mail-02B4A244-0F73-4861-908F-B7911C91C528
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printableYes. Import RAS.exe to your IDE of choice. Then you=E2=80=99ll be able to se=
e the RASController class and it=E2=80=99s library of procedures.=20Sent from my iPhone
> On Sep 18, 2018, at 6:27 PM, Damienhua [via HEC-RAS Help]
wrote:
>=20
> is the ras.exe itself is the controller ,so we can import it directly?=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/where-to-find-the-controller-in-=
the-HEC-RAS-files-tp6337p6338.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-02B4A244-0F73-4861-908F-B7911C91C528
Yes. Import RAS.exe to your IDE of choice. T=
Content-Type: text/html;
charset=utf-8
hen you=E2=80=99ll be able to see the RASController class and it=E2=80=99s l=
ibrary of procedures.Sent from m=
y iPhoneOn Sep 18, 2018, at 6:27 PM, Damienhua [via HEC-RAS H=
elp] <ml+s1091112n63=
[email protected]> wrote:is the ras.exe itself is the controller ,so we can import it direct=
ly?=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:
To start a new topic under HECRAS Controller, email [email protected].=
com
NAML=
–Apple-Mail-02B4A244-0F73-4861-908F-B7911C91C528–
September 19, 2018 at 1:45 pm #13600DamienhuaParticipantThank u very much
