Welcome to the RAS Solution Forums HEC-RAS Help What to do when Plan number reaches 99? HEC-RAS 4.1.0
  • This topic has 3 replies, 467 voices, and was last updated 9 years ago by Anonymous.
  • #6137
    Exactly as per the subject. I have almost almost finished a project using HEC-RAS 4.1.0 in steady flow mode. Plan number has reached 99, and the software will NOT “click” over to 100? This is probably the dummest question – but I need guidance.
    #9984
    Vince Moody
    This is a program limitation. Not sure if the same issue exists in version 5.0.1, but give it a shot in the new version. For the older version there is no resolution; as a work around you could save a copy of your model and restart plan numbering in the new model directory.
    I’ve never seen an application of HEC-RAS that called for 99 plans, do you mind sharing what you’re working on?
    #9985
    I have also problem with hec ras limitation, like u.
    My problem is that I cannot enter more then 500 points per profile.
    I must trim my real georeferenced profile that has more then 1500 points.
    So I get profile that does not look like real, not even close.
    #9986
    You should be able to trim out excess points that are near each other using the cross section point filter. Is there a reason you’re keeping that many points. If your doing modeling 500 should be able to show the full cross section.
