Welcome to the RAS Solution Forums HEC-RAS Help Wet / dry cell in 2D flow area
  • This topic has 2 replies, 236 voices, and was last updated 6 years ago by sam1.
  • #7564
    sam1
    hi,
    after a simple 2d simulation in hec-ras, how can i get the information of the number if wet or dry cells in the flow area at differents time steps?
    #12669
    You would probably have to check the HDF files for this and write a script to automate it. I don’t think there is a way in Mapper to tell you this.
    #12670
    sam1
    yes, thank you for your answer, actually this is what i did. But in the HDF file you have the depth in each cell, so cell is considered dry if depth equal 0 and wet if depth>0. But to calculate the flood area extent, is there any other method than considering wet cells? Because the water may not cover all the cell so to calculate the flow extent not all the cell area should be considerd.
