Welcome to the RAS Solution Forums HEC-RAS Help Weird Error Message
  • This topic has 5 replies, 706 voices, and was last updated 11 years ago by Anonymous.
  • #5736
    I can’t seem to open HEC RAS Anymore, its giving me an error message that says
    “Unexpected Error; Quitting”
    any ideas?
    #9178
    Initially, I would uninstall and re-install HEC-RAS…. Check HEC-RAS’s recommendation for your computer configuration….O/S, RAM memory, Processor, etc
    #9179
    Yes i’ve done this.
    #9180
    Keymaster
    Return-Path: X-Original-To: [email protected]
    Received: from mail-pa0-f50.google.com (mail-pa0-f50.google.com [209.85.220.50])
    by mwork.nabble.com (Postfix) with ESMTP id D8DC117106E7
    for ; Thu, 12 Mar 2015 10:31:21 -0700 (PDT)
    Received: by paceu11 with SMTP id eu11so22195828pac.4
    for ; Thu, 12 Mar 2015 10:31:14 -0700 (PDT)
    d=gmail.com; s=20120113;
    bh=LZXIaWQ40oR9g4d6bz2WkoFX3UFdNFkNhMduP6r5SrE=;
    b=kBF7RHf6gzB4SQdA4BSc1qUS6e4eOXnwTGrnjR6ZbM4Drbgr3wwhfAxAJ60ppS+nqy
    0DWamdocokjI6B0xWXMEdyI9FDwm/Kcn+emRTW/6Ft47B4HApK5snYmt6tJVPn+6qgxN
    i4BPZJf+hS7tcP7TcpWfQ0w+08GGk+crxe74mijJPh10l7caa+TadwPY9MnkxisBpses
    8AkiZQFAXXbPyTDc5hzgXqecsdj/gnDouim8WTGrBxgqMy0o2fiNJebdj7i7xpg0unas
    81Tj1AJyYxZeWYO6CuqW8hb2Zc8KB9Z7NWSvD3qEd3RA5QO6JYmFura72JIbk4UVhnht
    C2zA==
    X-Received: by 10.66.216.40 with SMTP id on8mr44960276pac.27.1426181473891;
    Thu, 12 Mar 2015 10:31:13 -0700 (PDT)
    Received: from ?IPv6:2600:1010:b115:ee03:b559:fb53:d79b:c49e? ([2600:1010:b115:ee03:b559:fb53:d79b:c49e])
    by mx.google.com with ESMTPSA id fm3sm11964995pab.29.2015.03.12.10.31.12
    for
    Subject: Re: Weird Error Message
    From: The RAS Solution Content-Type: multipart/alternative;
    boundary=Apple-Mail-44895FB6-33D1-4D41-9782-784840CA3FA3
    X-Mailer: iPhone Mail (12A405)
    Message-Id: <[email protected]>
    Date: Thu, 12 Mar 2015 10:31:10 -0700
    To: “Nathan [via HEC-RAS Help]”
    Mime-Version: 1.0 (1.0)
    –Apple-Mail-44895FB6-33D1-4D41-9782-784840CA3FA3
    Content-Type: text/plain;
    charset=us-ascii
    Try rebooting windows. If that doesn’t work, you’ll need to reinstall HEC-RA=
    S.=20
    Sent from my iPhone
    > On Mar 12, 2015, at 4:46 AM, Nathan [via HEC-RAS Help] wrote:
    >=20
    > I can’t seem to open HEC RAS Anymore, its giving me an error message that s=
    ays=20
    >=20
    > “Unexpected Error; Quitting”=20
    >=20
    > any ideas?=20
    >=20
    elow:
    > http://hec-ras-help.1091112.n5.nabble.com/Weird-Error-Message-tp1416.html
    > NAML
    Content-Type: text/html;
    charset=utf-8
    Try rebooting windows. If that doesn’t work, you’ll need to reinstall HEC-RAS.
    Sent from my iPhone
    On Mar 12, 2015, at 4:46 AM, Nathan [via HEC-RAS Help] <[email protected]> wrote:
    any ideas?
    If you reply to this email, your message will be added to the discussion below:
    NAML
    –Apple-Mail-44895FB6-33D1-4D41-9782-784840CA3FA3–
    #9181
    I am experiencing the same problem. I have tried uninstalling and reinstalling the software. I actually uninstalled 4.1 when the 5.0 version failed to run after installation. Now I am unable to run the previous RAS versions.
    #9182
    CraigP
    We are having the same issue now with 5.07 and with previous versions. We have got around it previously by just upgrading to the next version if available. But now that we are on the latest version we had to try something else. The reboot of Windows made no difference.
    We are a Windows 10 professional site with re-directed personal folders (roaming profiles), so we tried running HEC-RAS 5.07 as a local administrator whilst still logged in as the regular user. This worked and HEC-RAS ran. Closed the software and ran the software as the regular user, and it worked also. Maybe that has fixed the issue for this user. Time will tell.
