Welcome to the RAS Solution Forums HEC-RAS Help Weir flow over bridge (SA/2D Area Conn)
  • #17925
    Kendall Rees
    Hello, I am somewhat new to HEC-RAS 2D. I was wondering if there is a way to view any weir flow over the SA/2D Area Conn bridge structures? I can see the weir flow happening in RAS Mapper but can only see the total flow when I pull results. Is there somewhere else I can look for this? Thank you.
    #17927
    Chris Goodell
    You would probably have to look deep into the plan HDF file. You might explore the HDF5 Write Parameters in the Output Options window and see if there is anything in there for you.
