I’m trying to run a simulation of a river that contains two storage areas, but when i try to run the flow simulation, it comes up with the error:
‘HEC-RAS Error – Incomplete data, the following errors were found:
Plan file: C:\soton\research project\hecras\hecras_files\RCOLE.p49
Geometry file: C:\soton\research project\hecras\hecras_files\RCOLE.g11
Flow file: C:\soton\research project\hecras\hecras_files\RCOLE.f01
River: “RIVER COLE” Reach: “REACH 1” RS:0.517 LS
– Weir data is not in increasing order, stationing needs to maintain (vertical walls) or increase. At point(s): Sta: 1.716 < 1.696 pt#: 1-2 Sta: 1.696 < 1.69 pt#: 2-3 Sta:
1.69 < 1.68 pt#: 3-4
At the station its referring to (0.517) is a storage area, but nothing about the storage area on the surface level seems to be out of the ordinary, the elevation doesn’t go any higher than the surrounding cross-sections of the river or anything. Has anyone else come across this issue?
Thanks!
