Welcome to the RAS Solution Forums HEC-RAS Help WATER SURFACE LEVEL PROBLEM
  • This topic has 0 replies, 75 voices, and was last updated 6 years ago by Anonymous.
  • #7632
    I am working on steady flow model with cross sections every 25 ft.
    When I run the model the water surface elevation is a straight line at an elevation much higher than the expected elevation.
    I tried to decrase the manning value and using smaller discharge but nothing change.
    I uploaded autocad civil 3d file and other files.
    https://easyupload.io/dnkk2m
    Any advice/suggestions would be helpful. Thank you.
