Welcome to the RAS Solution Forums HEC-RAS Help water surface elevation too high
  • #7656
    My student is modeling a mountain river and can’t get her measured discharge to match measured for water surface elevation for calibration. The channel is a pool-riffle system (restored) and has a gravel bed. The manning’s n has to be raised to ridiculously high to match. We are unsure what else to attempt to change to get a match. The overall slope matches measured water surface slope.
    #12790
    Manning’s n does not directly capture the large turbulence losses for steep high velocity streams.
    If you aren’t already familiar with it, lookup Jarrett’s equation. The RAS hydraulic manual has a short section on it.
