Welcome to the RAS Solution Forums HEC-RAS Help warnings in 1D/2D hec-ras unsteady flow simulation
  • #7020
    stud18
    Hello!
    I would like to ask if the result of running a stream unsteady flow 1D/2D simulation during a flash flood event is Finished without errors, but though there are listed some warnings in some of the cross sections of the stream, is the solution correct and accepted?
    Also, what is the physical explanation of those warnings?
    #11678
    Increase your Htab parameters within that section of cross sections and re-run the model
