I have made a simple unsteady flow model (prismatic channel) with a flow hydrograph as an upstream boundary condition and normal depth as a downstream boundary condition. After running this model once (let’s say base run), I added 2 Internal boundaries (IB) conditions (stage hydrograph) at 2 different cross-sections for my next run. The model runs fine when I enter IB in the table but when I give IB as a DSS file (created using hec-dssvue), the model throws a warning saying ” An error occurred in unsteady flow data units conversion”. I have to manually click ‘ok’ to start/run the model. This happens only when the model is in the SI system. When I run the same model in the US customary units, I don’t get any errors.
I have checked the consistency of my input units. It looks fine to me. I don’t understand why would there be a need to convert the unit of the unsteady flow data before running a model when everything is in the same unit system.
I am doing this to run a Monte-Carlo simulation, where I would change IB values in the DSS files.
Kindly, suggest.
I am using RAS 5.0.7 and Hec-dssvue 2.0.1.
