Welcome to the RAS Solution Forums HEC-RAS Help viewing hydraulic depth for all profiles simultaneously for a particular cross section
  • #6684
    suhani choudhary
    Hello
    I want to view hydraulic depth values for all profiles together for a particular cross-section as i do have around 100 profiles so it will be too time consuming to copy every sinle value
    for every profile.
    Is there any option?????
    #11013
    In the Profile Output Table, go to Options > Define Table and then select hydraulic depth. If you then select all profiles, you will be able to see the hydraulic depth for all profiles for a particular cross section.
