Welcome to the RAS Solution › Forums › HEC-RAS Help › Viewing HDF file in Arc
  • #6461
    I am having trouble getting the velocity Vectors to display in Arc. I have turned on the option to write the component velocity in the HDF file but I can’t get it to open in ARC I have followed the steps on this site http://desktop.arcgis.com/en/arcmap/10.3/manage-data/raster-and-images/wkflw-creating-a-mosaic-dataset-using-vector-field-template.htm
    but it says no new raster added to Mosaic. Any help would be appreciated!
    Thanks in Advance!
    #10581
    Toby
    Hi Jake,
    I have been trying to work with velocity data in the HDF files inside Program R. I think the issue for the ARC process is that the HDF data is not in a raster format. Even though much of your mesh could be in a structured grid, there will be some irregular points in your mesh. I have tried bringing in the xy (face points) data and the velocity data then interpolate between the irregular data to a raster surface.
    #R code
    xVel <- h5read("plan.p01.hdf", "Results/Unsteady/Output/Output Blocks/Base Output/Unsteady Time Series/2D Flow Areas/YOUR MESH NAME/Node X Vel") #I transpose the xy data FacePointXY <- t(h5read("plan.p01.hdf", "Geometry/2D Flow Areas/YOUR MESH NAME/FacePoints Coordinate") Take a look at the data with the HDF Viewer and you can pull out xy data and velocity data and save it as a csv if that helps get it to a shapefile and interpolate to a raster.
