Welcome to the RAS Solution › Forums › HEC-RAS Help › View Computation Log File…
  • #6483
    AJ
    I received the following message when I tried to view the Computation Log File (in the Unsteady Flow Analysis window under Options). I have selected to “Write detailed log output for debugging” under the Detailed Log Output tab under Output –> Output Options in the Unsteady Flow Analysis window. But for some reason the file is not getting written. And yes, I did select compute after I set RAS to write the file. Am I missing something?
    Does anyone have a solution to this?
    A few things I tried that did not work:
    1. I added dates to the “Optional specified time window…” section as this was an issue in previous versions.
    2. I closed and reopened RAS
    #10609
    Im having this same issue and its causing errors all over my model
