Welcome to the RAS Solution Forums HEC-RAS Help Velocity RAS Mapper_ Version 5.0
  • This topic has 6 replies, 937 voices, and was last updated 10 years ago by Anonymous.
  • #6021
    I just installed the new great version of Hec RAS 5.0 and I have some problems with the RAS Mapper. I hope someone can help me. I already loaded my terrain and also the projection and i run my plan with a steady flow simulation. When i open the RAS Mapper it shows me the results layer (Depth, Velocity, Water Surface Elevation as Layer but if check the box in front of the layer to show my results, nothing happens. The conection between results and terrain is correct. I don’t know why this happens. The stored map function works for depth and WSE, but not for my velocity. Why is the ON-the-fly-computation not working? Thanks for your help.
    #9756
    Vince Moody
    If you send me your model I’ll take a look at it.
    #9757
    Thank you Vince
    I resolved with official version of HEC-RAS 5.0. If open, it’s all ok
    Regards,
    Antonio
    #9758
    mat A.
    I have an error with velocity map (other maps are OK) :
    Does anyone know what it means ?
    Regards.
    #9759
    mat A.
    here is my case :
    test3.zip
    #9760
    munjal
    can you give me step to solved this problem sir.
    #9761
    Any luck with this issue?
