Don’t know if this is is what you have been asking and the problem is probably solved, but for anyone else who is stuck at this.
You have distribute your flow sections in a way that the you get velocity at desired cross section interval.
go to > Steady Flow analysis or Unsteady Flow analysis > Options > Flow distribution Locations > Set Global Subsection Distribution
select the number of segments for LOB,channel and ROB where you can view velocity profile
check page 11
https://www.novaregion.org/DocumentCenter/View/769/Chapter-07
Regards~
