Welcome to the RAS Solution Forums HEC-RAS Help Varying n value along the channel
  • #6620
    hshahad
    At first, thanks to all the contributors to this forum. This is an excellent source of knowledge.
    I am modeling a channel, which transitions from grass lined to concrete lined and back to grass lined.
    Lets say:
    XS1 (most US cross section)–> the channel begins as grass lined,
    XS2 (next cross section DS)–> grass channel ends and concrete lining begins,
    XS3 (next cross section DS)–> concrete lining ends and grass channel begins,
    As n values, I will be using 0.04 for grass channel and 0.015 for concrete lined portion. The way I have the n values is as follows: (To simplify my question, I am ignoring the overbanks)
    XS1 –> 0.04
    XS2 –> 0.015
    XS3 –> 0.04
    Can anyone please confirm if I am correct in my approach? To the best of my knowledge, every cross section represents the reach starting from that point until it reaches the next cross section downstream. I need your help to confirm if my understanding is correct.
    Thanks a lot…
    #10874
    HEC-RAS interpolates between cross-sections and does not use a single xs until the next xs. You would need additional xs to account for the roughness changes. I would just add additional xs 1 ft away for the areas where roughness is changing.
    #10875
    hshahad
    Thank you so much…
    I ran a quick test. First, with only one cross-section near the change in roughness with n = 0.04, where the channel changed from concrete to grass. In the other one, I had two cross-sections. One XSec with 0.015 where the concrete ends, another one 1 ft downstream of it for the beginning of grass channel with n = 0.04.
    The resultant water surface profile for both scenarios are identical. Any idea?
    Thanks again…
    #10876
    could you post the model somewhere?
