Welcome to the RAS Solution Forums HEC-RAS Help Values in velocity plot in ras mapper don’t match with model values.
  • #15235
    Francisco Guerrero
    Hi, I’m modeling a stream in 1D steady flow, but when I try plotting the 2D interpolated velocity graph in RasMapper, the values of the plot don’t match with the values obtained in the model. I tried to do the model again but with the same problem. I don’t know if RasMapper has another form to compute the velocity outside of the values already calculated from the 1D model. I’m using version 6.1.0
    Thanks for the responses
