Welcome to the RAS Solution › Forums › HEC-RAS Help › Using RAS mapper result
- This topic has 3 replies, 1,464 voices, and was last updated 10 years, 1 month ago by Nafi.
February 14, 2016 at 10:40 pm #5985NafiParticipant
Return-Path:
Received: from mail-io0-f177.google.com (mail-io0-f177.google.com [209.85.223.177])
by mwork.nabble.com (Postfix) with ESMTP id 44E0614928FE9
for; Sun, 14 Feb 2016 10:33:25 -0800 (PST)
Received: by mail-io0-f177.google.com with SMTP id z135so69208171iof.0
for; Sun, 14 Feb 2016 10:41:03 -0800 (PST)
d=gmail.com; s=20120113;
h=mime-version:date:message-id:subject:from:to:content-type;
bh=eI39OyS3G+pp/XGP4hFsvXBxYcdAjHWIqLm/9Lt4Z2o=;
b=jzihjX467IQPTsVsOQFuOu1r3l//7VchQkC/B1E2o1n6VLcS5Vx5vduQxbZm7n2p6w
mWnmimW9AyOwOriRtXs0unIaC9+hYzLbneoQj/4FN0HdAHUv+u8B1GZYuvxENYwKFrM3
Sen1ZO49mefSV2M91AzxyEHauxb3TY4tEoXs7nQd+/ucDGNg8k8US8BeK6IV/cFNGjlx
VROvuE/OsHD45Fw8YNh4rmOU5jmNIrsyEY9ZDtXbF8uNFq6/JJsoeeigdiUu5jbNreA0
aeGJ02KGSX/gqbSdk900TRBNIg35OtDpzx5lQ5MsLkMkP+mzOMVqLKyz/+YgyxqXeBRc
5A7Q==
d=1e100.net; s=20130820;
h=x-gm-message-state:mime-version:date:message-id:subject:from:to
:content-type;
b=R0MLDn9+ISkArgg3cCOyaIAJkZJctJPRQXMQhoNDfYrg5dv6L3IPu90wiBrruamKMN
5HHwRaKGswTcW6+5LYsWi+M/sZzfKHPgZVAypEp6XxqKPXiAzDZnmZHi/rmFYB4dQrVo
xP75AWny+xfOHvqd41AFishN84TRhBpSNKnDXm5Sd+ZSxFMeB49/i0MyPRIbKGINcD8a
t/fFzWhX3K+jaVdPXQqriY+UyjEscIudM0rSDDkL/nw1bomj0Nfez9J65Uhw3r2W5ZPk
iYJd1UIBOqaSVmrsqn3RHdjFvgx4m7iWZf3d3k4HSrQQMPQnTGLAeA3I0SnaGSd+Vs83
yoLA==
X-Gm-Message-State: AG10YOSEsuL0ujmGptmmfdqBcPK720aD44sATWuWnIVhNaHzcD0LNZUIRE6cZLkupxqoyhiLLcKeOB+PV6PmVQ==
MIME-Version: 1.0
X-Received: by 10.107.137.142 with SMTP id t14mr14868260ioi.172.1455475258215;
Sun, 14 Feb 2016 10:40:58 -0800 (PST)
Received: by 10.107.156.73 with HTTP; Sun, 14 Feb 2016 10:40:58 -0800 (PST)
Date: Sun, 14 Feb 2016 10:40:58 -0800
Message-ID:
Subject: Using RAS mapper result
Content-Type: multipart/alternative; boundary=001a113f8f2cbed493052bbf3de7–001a113f8f2cbed493052bbf3de7
Content-Type: text/plain; charset=UTF-8I have produced results from the 2D model , but cant find a way to use the
result for calculating inundation area . Is there any way to export the
result in GIS or calculate the inundation area?–001a113f8f2cbed493052bbf3de7
Content-Type: text/html; charset=UTF-8I have produced results from the 2D model , but cant find a way to use the result for calculating inundation area . Is there any way to export the result in GIS or calculate the inundation area?–001a113f8f2cbed493052bbf3de7–
February 15, 2016 at 2:43 am #9638cameronParticipantYou can save the depth results as a grid by setting up the map parameters in Mapper. This can then be used to create an inundation map. The other option is to set up an inundation map result layer in Mapper. The link below tells you how to do it.
http://hecrasmodel.blogspot.com/2016/02/post-processing-creating-inundation.html
February 15, 2016 at 3:01 am #9639Vince MoodyParticipantThere’s an even easier way than exporting a depth GRID and processing in GIS: In Mapper, in the results of your simulation right click on one of the layers (e.g. Velocity) and select “Edit Map Parameters”. This brings up a dialog that lets you customize the displayed results for that layer and one of the options is Inundation Boundary. Select this option and the appropriate profile and then “Save Map”. You may need to recompute this new map result, so go to the Tools menu in Mapper, then Manage Map Results. Select your newly created inundation Boundary layer and click Compute/Update stored maps.
This creates an inundation area shapefile in the plan name in your model directory. Alternatively, you can right click that layer and export to a new shapefile to the directory of your choosing. Sounds like a lot of steps, but should take all of 30 seconds.
June 23, 2017 at 12:17 am #9640RileyParticipanthave you run into the issue with it not creating the shapefile? it won’t create the boundary for me. any thoughts?
