Welcome to the RAS Solution Forums HEC-RAS Help Using Output_NodeOutput for two different plans within the same sub
  • #6198
    Hi Chris,
    I am trying to use the Output_NodeOutput subroutine twice within the same sub. I have two different plans that I would like to read from. When I call the Output_NodeOutput to read from the second plan, it is not reading it but still looking at the first one. I did call the second plan prior to the Output_NodeOutput sub using RC.Plan_SetCurrent.
    here’s an abridged version of the code:
    Sub PeakTimeWet()
    Dim RC As New HECRASController
    ‘open a HECRAS project
    Dim strRASProject As String
    Worksheets(“Input”).Activate
    Range(“C2”).Select
    strRASProject = ActiveCell.Value
    RC.Project_Open strRASProject
    RC.ShowRas
    Dim strBreachPlan As String
    Dim strWetWeatherPlan As String
    Range(“C3”).Select
    strWetWeatherPlan = ActiveCell.Value
    Range(“C7”).Select
    strBreachPlan = ActiveCell.Value
    RC.Plan_SetCurrent strWetWeatherPlan
    ‘determine the number of rivers and reaches
    Dim lngNumRiver As Long
    Dim lngNumReach As Long
    Dim strRiver() As String
    Dim strReach() As String
    Dim lngRiverID As Long ‘River ID
    Dim lngReachID As Long ‘Reach ID
    RC.Geometry_GetRivers lngNumRiver, strRiver()
    Range(“C4”).Select
    lngRiverID = ActiveCell.Value
    RC.Geometry_GetReaches lngRiverID, lngNumReach, strReach()
    Range(“C5”).Select
    lngReachID = ActiveCell.Value
    ‘Determine the number of cross sections
    Dim lngNumRS As Long ‘Number of river stations
    Dim strRS() As String ‘Name of river stations
    Dim strNodeType() As String ‘Node types
    RC.Geometry_GetNodes lngRiverID, lngReachID, lngNumRS, strRS(), strNodeType()
    ‘Peak stage from wet weather run
    Dim sngWetStage() As Single: ReDim sngWetStage(1 To lngNumRS)
    For k = 1 To lngNumRS
    If strNodeType(k) <> “IS” Then
    sngWetStage(k) = RC.Output_NodeOutput(lngRiverID, lngReachID, k, 0, 1, 2)
    End If
    Next k
    ‘Loads array with breach flow data
    Dim sngBreachStage() As Single: ReDim sngBreachStage(1 To lngNumRS)
    RC.Plan_SetCurrent strBreachPlan
    sngBreachStage(k) = RC.Output_NodeOutput(lngRiverID, lngReachID, k, 0, 1, 2)
    End If
    Next k
    End Sub
    Any thoughts?
    Christine
