Welcome to the RAS Solution › Forums › HECRAS Controller › Using HECRAS Controller in csharp
- This topic has 3 replies, 634 voices, and was last updated 7 years, 11 months ago by iamchriskelley.
April 13, 2018 at 9:07 am #8213iamchriskelleyParticipant
Hi Everyone,
Thanks to posts on this forum I’ve gotten the HECRASController running in VBA, and now I’d like to get it running in C# (in the back end of a Unity3D application). I’ve added the reference to my C# project and the COM interop is working fine for simple things like Project_Open() and HECRASVersion().
I’m currently stuck on Compute_CurrentPlan. In VBA I can easily do this in a few lines, like:
Sub foobar()
Dim hrc As New HECRASController
Dim i As Long
Dim msgs() As String
Dim b As Boolean
hrc.Project_Open “[path]”
b = hrc.Compute_CurrentPlan(i, msgs(), True)
End SubC# is much pickier with types though, and Compute_CurrentPlan in C# seems to require an Array type (not a string[] array) passed by reference.
Currently I have (apologies for not yet knowing the code markups for this forum):
using RAS503;
using System;
using UnityEngine;public class HECRAS_runner0 : MonoBehaviour {
public HECRASController hrc;
void Start () {
int nmsg = 0;
bool block = true;
Array sa = Array.CreateInstance(typeof(string), 100);
//sa.SetValue(“”, 0);hrc = new HECRASController();
Debug.Log(hrc.HECRASVersion());
hrc.Project_Open(“[path]”);
Debug.Log(hrc.Project_Current());
Debug.Log(hrc.CurrentProjectTitle());
hrc.Compute_ShowComputationWindow();
Debug.Log(hrc.CurrentGeomFile());
Debug.Log(hrc.CurrentSteadyFile());
Debug.Log(hrc.CurrentProjectFile());
Debug.Log(hrc.CurrentPlanFile());try
hrc.Compute_CurrentPlan(ref nmsg, ref sa, ref block);
catch (Exception e)
Debug.Log(e.ToString());
}hrc.Project_Save();
hrc.Project_Close();
hrc.QuitRas();
Debug.Log(“done.”);
hrc = null; //kills the process faster than waiting for GC
}(The capacity of sa was set to 100 to try and give enough room; setting it to 1 or 1000 doesn’t seem to make a difference). This gives the following error:
System.ArgumentException: Value does not fall within the expected range.
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR (Int32 errorCode) [0x0000d] in /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Runtime.InteropServices/Marshal.cs:1031
at (wrapper cominterop) RAS503.HECRASControllerClass:Compute_CurrentPlan (int&,System.Array&,bool&)
at (wrapper cominterop-invoke) RAS503.HECRASControllerClass:Compute_CurrentPlan (int&,System.Array&,bool&)
at HECRAS_runner0.Start () [0x000b4] in C:\Users\Admin\Documents\HEC-RAS_demo\Assets\HECRAS_runner0.cs:32
UnityEngine.Debug:Log(Object)
HECRAS_runner0:Start() (at Assets/HECRAS_runner0.cs:36)Has anyone had experienced using HECRASController in C# or another strongly typed language and have any insights?
Thanks!
ChrisApril 13, 2018 at 9:54 pm #13581Chris G.KeymasterChris, you might be breaking new ground doing this in C #. Thanks for blazing the trail. I wish I had C# experience to help. Hopefully someone else can chime in. If you figure it out, please post here. Thanks-
ChrisApril 14, 2018 at 4:05 am #13582iamchriskelleyParticipantThanks for the reply, Chris. I’ll keep plugging away. If anyone has any suggestions please let me know.
April 16, 2018 at 7:50 pm #13583iamchriskelleyParticipantOkay, got it! The following code is working in C# (with a reference to the HECRASController):
int nmsg = 0;
bool block = true;
Array sa = null;
hrc.Compute_ShowComputationWindow();try
catch (Exception e)
Console.WriteLine(e.ToString());
hrc.Project_Save();
hrc.QuitRas();The System.Array has to be nulled for Compute_CurrentPlan() to accept it (confirmed by Caleb Buahin who wrote the RCAFF application in C#).
