Welcome to the RAS Solution Forums HEC-RAS Help Use of inline Structure Outlet Rating Curve
  • This topic has 1 reply, 847 voices, and was last updated 10 years ago by JEM.
  • #6026
    JEM
    I am trying to enter an inline structure in the new HECRAS 5.
    My confusion is on the use of the outlet RC. Will the flow based on the outlet RC be additional to what flows (internally calulated) over the weir using the weir coeffcients and equations?
    If so, what if i prefer using a rating curve instead of the weir equation. Can i just make the weir coefficient zero so only the RC is used? Will it work?
    Or will the calculation just ignore the weir coefficients and instead use the RC when the RC is provided?
    #9772
    JEM
    Ok, i found out that the RC is just additional outflow from the structure.
