Welcome to the RAS Solution › Forums › HEC-RAS Help › Urgent Help! – PLEASE – Unsteady Flow Analysis
- This topic has 0 replies, 391 voices, and was last updated 7 years, 3 months ago by Anonymous.
December 1, 2018 at 9:42 pm #7140AnonymousGuest
Hey Guys,
I need help urgently, since I have to present the results soon. Can someone please help me? I cannot seem to get it to work. I have been reading that I may need to create a DSS file, but I understood that HEC RAS would create it. Error Message below:
Plan: ‘Perimeter Park Unsteady Flow’ (MBProject.p02)
Simulation started at: 01Dec2018 12:35:40 PM
Using 64 Bit Computation EnginesWriting Geometry
Perimeter Park: Mesh property tables are current.
Perimeter Suburb: Mesh property tables are current.
Completed Writing GeometryGeometric Preprocessor HEC-RAS 5.0.5 June 2018
Finished Processing Geometry
Starting to copy Geometry Data to Results
Completed copying Geometry Data to ResultsPerforming Unsteady Flow Simulation HEC-RAS 5.0.5 June 2018
Subroutine HDF_OPEN_UN_RUNUnsteady flow encountered an error.
Computations Summary
Completing Geometry(64) 1
Preprocessing Geometry(64) <1
Complete Process 2
#000: ..\..\src\H5G.c line 310 in H5Gcreate2(): unable to create group
major: Symbol table
#001: ..\..\src\H5Gint.c line 194 in H5G__create_named(): unable to create and link to group
major: Symbol table
#002: ..\..\src\H5L.c line 1638 in H5L_link_object(): unable to create new link to object
major: Links
#003: ..\..\src\H5L.c line 1882 in H5L_create_real(): can't insert link
major: Symbol table
#004: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
major: Symbol table
minor: Object not found
#005: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
major: Symbol table
minor: Callback failed
#006: ..\..\src\H5L.c line 1674 in H5L_link_cb(): name already exists
major: Symbol table
minor: Object already exists
#000: ..\..\src\H5D.c line 170 in H5Dcreate2(): unable to create dataset
major: Dataset
#001: ..\..\src\H5Dint.c line 439 in H5D__create_named(): unable to create and link to dataset
major: Dataset
major: Links
major: Symbol table
major: Symbol table
major: Symbol table
major: Symbol table
minor: Object already exists -
