Welcome to the RAS Solution Forums HEC-RAS Help Updating Centerline Causing Straight “Rivers” to Appear
  • This topic has 5 replies, 83 voices, and was last updated 5 years ago by Anonymous.
  • #7666
    I am trying to update a current model with historic planform data. I am able to import the historic centerlines, banklines, and flowpaths. I am using existing cross sections to not interrupt any 1D/2D connections. I would like to keep the river stationing the same to make visualization/comparison easier at the end so it is easier to compare the same (spatially) cross section for the different conditions. So, I have to past in the previous stationing to the cross section attribute table once I add the historic lines. However, once I added all my new features, recomputed reach lengths and bank stations in RAS Mapper, and made sure the cross section attribute table showed the correct stationing, I saved the geometry and my original (the current conditions) can back (changing the CL is the first step I take and several “saves” ago). This was the closest I got it to working before getting an issue.
    I went back and tried to just add back the historic centerline and compute what I needed, but then I started having the issue again where a straight “river” feature would appear between two cross sections. Sometimes it is between random cross sections on difference rivers, and sometimes it is between the first and last cross section of each river in the system. I try just deleting them, but at least one always appears once I save. It also causes the cross sections to rearrange slightly in the attribute table.
    Does anyone have any ideas on what it causing this or how to resolve? Is is because RAS Mapper is georeferenced and knows the river stationing is not being updated?
    Note: I am also trying to avoid updating the river stationing so I don’t have to manually update the ~150 structures along the rivers I am changing (bridges, inline structures and lateral structures). Unless, does anyone know how to have these automatically update once cross sections stations are updated? This may deserve a forum post of its own.
    #12798
    Kathleen
    Here is an example of what the straight “rivers” look like.
    #12799
    Do you have any cross-sections where the stream center line is not in side the two bank stations?
    #12800
    Kathleen
    Yes, but I have been re-computing the bank stations (and reach lengths) by editing the cross sections, right clicking, compute, etc.
    #12801
    Do you have any cross-sections that cross two stream centerlines (tributary cross-sections overlapping main river)?
    #12802
    Kathleen
    No.
    Also, just now it was looking good until I changed the River attribute table to show the correct junction names for the US and DS name and the straight rivers reappears. Not sure if that gives any clues.
