So I’m newish to unsteady flow modeling in RAS and I’m struggling to troubleshoot the inevitable instabilities in the models I produce. I have taken an ASCE webinar, but it was not the most detailed.
My model has a steeper area at the beginning that I hypothesized was supercritical, which can cause instabilities. My thought was to run the model in steady state and use the modified puls method at every cross section to determine where the model was supercritical.
The result is:
Which is what I would expect to see for an unsteady model. As I thought, the model does go supercritical at the steep beginning, so my thought was to keep using modified puls at the beginning but let it switch to the full st venant equations (which are more accurate) for the later part.
Unfortunately, this causes the model to go unstable:
With the hydrograph and rating curve of a downstream cross section completely haywire:
This is versus the hydrograph and rating curve of when it was still modified puls:
My model can be downloaded from here: https://drive.google.com/open?id=0Bzzp7FkGAwnAOGlDbXhqWGxNOGs
Any help would be greatly appreciated.
