Welcome to the RAS Solution › Forums › HEC-RAS Help › Unsteady flow Simulation error
- This topic has 5 replies, 966 voices, and was last updated 8 years, 8 months ago by Jack smith ASA.
July 19, 2017 at 12:13 pm #6546Jack smith ASAParticipantJuly 19, 2017 at 6:49 pm #10742cameronParticipant
Those are common error messages in Unsteady HEC-RAS which just states it couldn’t converge to a solution within the iterations so it picked the best value and moved on. Depending on what type of study you are doing, the error amount may or may not matter. For instance, with dam breach studies I try to keep the error value below 1.0 and for other studies below 0.5 or less depending on how complex the model is.
In your case the two largest errors occur right at the beginning of the simulation and so the error would have something to do with your initial conditions. Not sure the purpose of the study, but I would probably not worry about the error as it is not that large and goes away eventually.
July 20, 2017 at 7:13 am #10743Jack smith ASAParticipantThank you so much for your suggestion. I am doing a pumping station optimization project in a river network, so water surface elevation needs to satisfy a certain accuracy. The errors in the picture is just a small part of errors in the simulation and the error grows as the pump station scale increases which can reach as much as several meters. In this example , the 8 pump stations are set to be instantaneous opening at the water surface elevation of 1.0 m and closing at 0.4 m. Since the errors happened in RS near pump station, the error may be induced by the instantaneous opening and closing of pump stations. I have tried to increase the number of iterations,decrease computation interval, turn on mixed flow regime,but that doesn’t help. Is there any other way to solve it? Looking forward for your reply, thank you.
July 20, 2017 at 7:29 am #10744cameronParticipantcould you do a gradual open and gradual close of the pumps? maybe only turn on a couple at 1.0m and a couple more at 1.1m and so forth? Not sure how big the pumps are, but 8 starting or stopping at the same time might be causing a shock to the models.
July 20, 2017 at 9:05 am #10745Jack smith ASAParticipantJuly 20, 2017 at 6:26 pm #10746cameronParticipantBased on the plot you provided, it appears that turning on all 8 at the same time is overkill until about hour 8. It also appears that your starting stage is above 0.4m which is when the pumps turn off. Have you tried a warm up period or a run where the pumps do not start out on? This is possibly why you are getting an error at the beginning of your run. Also it is probably not good for the pumps to be turning on, off, and back on again so quickly. That just tells me that you have too many pumps turned on or you have the wrong size of pumps.
When do the largest errors occur? Does it occur during the highest stages at the pump when all the pumps are running full (hour 8 to 14) or before and after? If it is before or after, it is not going to impact the max wse plot (if that is what you care about). If it is during the peak stage, that may impact the max wse which depending on the error may be ok.
It is very difficult to get a complex unsteady model that has no error and is in some cases impossible.
