I am having trouble with unsteady flow analysis. When I run the unsteady analysis I receive the errors“extrapolated above rating curve” and “solution solver went unstable at iteration 13 used computed changes in flow and stage at minimum error.” When I look at my profiles the water surface elevation for certain cross sections are much higher than the previous cross or next cross sections. I have edited the HTAB parameters for the cross section to 100 interval, 0.5 increment, and copied the inverted elevation but it doesn’t fix the problem. Is this a problem with my Manning’s roughness coefficient? Any help is appreciated.
