Welcome to the RAS Solution › Forums › HEC-RAS Help › Unsteady flow encountered an error
- This topic has 8 replies, 2,940 voices, and was last updated 9 years, 1 month ago by Anonymous.
January 21, 2017 at 1:14 am #6330AnonymousGuest
I’m trying to calculate the floodplain of a river using unsteady flow analysis. Halfway through the unsteady flow simulation, I get the following error, with the first two lines in black text and the following five in red:
Subroutine HDF_WRITE_RULE_SETUnsteady flow encountered an error.
#000: ..\..\src\H5D.c line 437 in H5Dget_space(): not a dataset
minor: Inappropriate typeAny idea what I’m doing wrong?
January 23, 2017 at 9:40 am #10339cameronParticipantHave you tried deleting all the hdf file and rerunning? Also make sure you are using the latest version of HEC-RAS.
January 23, 2017 at 5:26 pm #10340AnonymousGuestWhen I do that, I get these errors:
Data for 2D Area is missing.
Check the Geometry Associations and
the 2D mesh for problems.Unsteady flow encountered an error.
#000: ..\..\src\H5G.c line 463 in H5Gopen2(): unable to open group
major: Symbol table
minor: Can’t open object
#001: ..\..\src\H5Gint.c line 320 in H5G__open_name(): group not found
major: Symbol table
minor: Object not found
#002: ..\..\src\H5Gloc.c line 430 in H5G_loc_find(): can’t find object
major: Symbol table
#003: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
major: Symbol table
#004: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
major: Symbol table
minor: Callback failed
#005: ..\..\src\H5Gloc.c line 385 in H5G_loc_find_cb(): object ‘McComb river’ doesn’t existAnd yes, I do have the latest version.
January 23, 2017 at 7:14 pm #10341cameronParticipantdid you recompute the tables for the 2D area? Are there any problems with your mesh?
January 23, 2017 at 7:41 pm #10342AnonymousGuestI did, and there weren’t.
January 23, 2017 at 10:24 pm #10343AnonymousGuest– deleted –
January 25, 2017 at 7:03 pm #10344AnonymousGuestI feel I should add that this error occurs the moment I begin the unsteady flow simulation. The geometry preprocessor works fine, and steady flow simulations work fine as well, but as soon as hec-ras tries to run an unsteady flow calculation, that error pops up.
January 27, 2017 at 7:47 pm #10345AnonymousGuestI have resolved this error, and will now explain what I did wrong in case someone in the future has the same problem.
In my river, there was a small inline dam with a square opening. I figured it would be easier to represent this with a gate than a culvert, even though it never opened or closed. I implemented rules for this gate to make sure it stayed open; however, it was these rules that caused the error, for I believe I had entered them improperly. The instant I deleted them and replaced the gate with a box-shaped culvert, everything worked fine.
February 14, 2020 at 11:15 pm #10346AnonymousGuestI keep getting the following error:
“Unsteady flow encountered an error
Error starting unsteady simulation – Stopping compute process”This only happens when I run the transient model with the “Sediment” box checked. I swear this model worked last year. I can think of any changes I made to it since. Please advise. Thanks.
