I have a very low gradient channel with a bridge across it. I’m modeling the bridge as a box culvert in 2D. I’ve tried making grid cells connected to the culvert large to have sufficient volume, but am not sure I’ve made them large enough. The configuration is limited by a break line, an internal 2D connection.
The upstream and downstream water surface elevations apparently switch too easily. The grid cells iterate to the maximum count, very frequently, and I end up with large volume errors.
Any thoughts on what I need to do?
