Welcome to the RAS Solution Forums HEC-RAS Help unstability in model 1D/2D
  • #6356
    KOFFI
    Hello . I realize a 1D / 2D model I have difficulties with the stability of the model. After a simulation here are the errors that appear. thank you to answer me.
    Plan: ‘Simulation1’ (MODELE_1D_2D.p01)
    Simulation started at: 16Feb2017 04:41:50 PM
    Using 64 Bit Computation Engines
    Writing Geometry
    Surface: Mesh property tables are current.
    Completed Writing Geometry
    Geometric Preprocessor HEC-RAS 5.0.3 September 2016
    Finished Processing Geometry
    Writing Event Conditions
    Event Conditions Complete
    **** ERROR: Solution Solver Failed ****
    Unstable for Initial Iteration at 31DEC1987 2400
    Writing Results to DSS
    Finished Writing Results to DSS
    Reading Data for Post Process
    Simulation went unstable at: 01Jan1988 00:01:00
    Running Post Processor HEC-RAS 5.0.3 September 2016
    Finished Post Processing
    Stored maps were not written because the simulation did not complete.
    Computations Summary
    Completing Geometry 4
    Preprocessing Geometry(64) 2
    Unsteady Flow Computations(64) 1:42
    Writing to DSS(64) <1
    Post-Processing(64) 1
    Complete Process 1:53
    #10411
    Would need some more information to help.
