Welcome to the RAS Solution Forums HEC-RAS Help Unrealistic vertical adjustment at Rinne 2.7
  • This topic has 5 replies, 2,301 voices, and was last updated 12 years ago by Anonymous.
  • #5417
    I have a problem withe my
    Sediment Transport Analysis Version 4.1.0 Jan 2010.
    When I want to compute the Sedimenttransport I always get the Error:
    “Unrealistic vertical adjustment at Rinne 2.7”
    I can’t find the problem for this.
    Can please somebody help?
    Thanks for your effort 🙂
    #8662
    I am struggling with the same error message. Anyone seen this or figured out a way to resolve? Any help is appreciated.
    #8663
    Keymaster
    There are so many potential causes for this error. However, it is common for that error to happen when you have an abnormally large amount of deposition in a cross section. This can occur if that cross section is much larger than adjacent cross sections, if ineffective flow areas and mobile bed limits are not properly defined, or if there is just something preventing sediment from passing through that cross section. Check your cross sections. Make sure you don’t have a sudden decrease in velocity where the unrealistic change is happening. If so, you may need to better define contraction and expansion through that reach by including and/or adjusting your ineffective flow areas.
    @RASModel
    #8664
    Hello!
    i have the same problem now
    i have checked allready width of all cross sections and they are almost the same
    i have a problem at one certain cross section, but when i have done all this changes in this cross section the sediment analisys still doesn’t work.
    which other problems could be here?
    thank you
    #8665
    Does the slope change or ineffective area change near that cross-section?
    #8666
    and what suggestion for this problem? do i need to add more cross section with less interval?
