Welcome to the RAS Solution › Forums › HEC-RAS Help › Unhandled exception in RAS Mapper, HEC-RAS 4.1.0
- This topic has 4 replies, 2,135 voices, and was last updated 10 years, 5 months ago by Anonymous.
March 30, 2016 at 2:23 pm #6036AnonymousGuest
Hi
my RAS Mapper suddenly stopped working. I have allready made succesfully many floodmaps in the same project. When I try to open Mapper it starts to load information but end up to an unhadled exception. Message says: Parameter is not valid. After pressing a continue button it gives a Run-time error ‘-2147024809 (80070057)’: Parameter is not valid. Under you can find some information about error. It happens only with this project.
Any ideas what to do? I still have couple floodmaps to do.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
at System.Drawing.Graphics.DrawLines(Pen pen, Point[] points)
at RasMapperLib.Polygon.PlotFeaturePenBrush(Plot plot, Pen Pen, Brush brush, Graphics g)
at RasMapperLib.Polygon.PlotFeature(Plot plot, Layer layer, Graphics g)
at RasMapperLib.Layer.(Plot , Graphics )
at RasMapperLib.Layer.PlotFeatures(Plot plot, Graphics g)
at RasMapperLib.Plot.(Graphics , TreeNodeCollection )
at RasMapperLib.Plot.PlotFeatures()
at RasMapperLib.RASMapper.LoadRasMapFile()
at RasMapperLib.RASMapper.(Object , EventArgs )
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
RasMapperLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/4.1.0/RasMapperLib.DLL
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 2.0.50727.5494 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
—————————————-************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.March 31, 2016 at 5:15 pm #9787Lonnie AParticipantHere is what I’ve had to do when I’ve had Mapper crashing that you might try.
If you have a small storage area graphic and you are zoomed out this will cause this sometimes. You need to try and zoom in on the small area then close mapper and reopen.
Other times I’ve had to delete the mapper files from the project folder and start mapper over again.
April 1, 2016 at 1:33 pm #9788AnonymousGuestThank you for your answer Lonnie.
I can’t try your first suggestion, because Mapper crashes before I am able to do anything.
I have to try your second suggestion. The problem is that I don’t no where to find those Mapper files. I tried to find correct filetypes using earlier post but didn’t find any that could be from Mapper. How can I recognise those files?
Post I used is: http://hecrasmodel.blogspot.com/2013/04/hec-ras-file-types.html
April 1, 2016 at 7:17 pm #9789cameronParticipant*.rasmap is the mapper file.
April 1, 2016 at 10:11 pm #9790Lonnie AParticipantCouple things I think you can try to get past mapper crashing as soon as you open it (if the storage area is the issue):
Try creating another plan with a dummy geometry and have that as the current plan before you try to open Mapper. Once mapper opens you can zoom in on the small storage area graphic and then close mapper. Go back to RAS and set plan to your run of interest and then go back to mapper.
Or
If it is a small storage area that is causing the problem you can either drag points to make the storage area graphic larger or delete it. This might get you into mapper without the crash.I believe what the problem is with small SA graphics has to do with the display compressing the small polygon into a single point….
