Welcome to the RAS Solution Forums HEC-RAS Help “Unhandled Exception” errors in August 2015 Beta Version
  • This topic has 7 replies, 2,752 voices, and was last updated 10 years ago by Anonymous.
  • #5925
    When trying to develop terrain in RasMapper, I am getting the following errors:
    “Unhandled exception has occurred in a component in your application… The path is not of a legal form” or
    “Unhandled exception has occurred in a component in your application… No row can be added to a DataGridView control that does not have columns. Columns must be added first”
    I don’t believe there is a problem in the data because I have tried to create terrain from numerous files, including .flt files I had used in the previous beta version and .adf files that came from a tutorial.
    I am going to try a re-install this version, but has anyone else experienced this problem and does anyone know of potential solutions?
    Thanks in advance!
    #9553
    Just to update the re-install did not solve the problem.. I’ve gone and built terrain from the same files in the previous (10/2014) release so it looks like the files are not the problem and it might be some kind of bug…. I have also tried on two different computers with the August 2015 version and had the same problem.
    Any suggestions would be greatly appreciated.
    Thanks again
    #9554
    Same issue here. HEC-RAS 5.0, have it installed on Windows 8.1 64bit, Windows 7 64bit and Windows 7 32bit. RAS Mapper–>Tools–>New Terrain (after setting the projection). The error is:
    Unhandled exception, The path is not of a legal form.
    #9555
    …It just occurred to me that maybe I should have created a new HEC-RAS Project before starting to try to create a new terrain.
    To fix this issue I first went to HEC-RAS’s File Menu–>New Project
    Then went to RAS Mapper–>Tools–>Set Projection for Project
    Then RAS Mapper–>Tools–>New Terrain
    #9556
    Thank you, that was very helpful!
    #9557
    I run into the same issue and creating a new HECRAS project first fixes the problem.
    Thank you a lot!
    #9558
    I tried by creating new project as was directed and it worked.
    #9559
    I have used your help in 2020, thank you!
