When I computed 2D flow area hydraulic tables, it shows that it is Unable to compute face tables. The terrain associated with this geometry does not completely cover the 2D flow area. See face(s) #(239).
I located the face mentioned, but I am not able to figure out what is wrong with that face.
When I tried to edit the 2D flow area, more number of faces geometry appeared.
What is the solution in this case?
This topic was modified 3 years, 8 months ago by VINEELA NANDAM.
Its pretty simple, just make sure your 2D extents do not extend beyond the limits of the terrain. you also must make sure the geometry is associated with that terrain.
