Welcome to the RAS Solution Forums HEC-RAS Help Two LS connected to the same 2D cell
  • #7186
    SaraA
    I am trying to run a 2D model connecting to a 1D river using the normal 2D equation.
    When I split the lateral structures to make them aroun 500m lenght and avoid problems weir/cell elevation, I face another problem when the same 2D cell is shared by two LS and using the normal 2D equation:
    Two lateral structures cannot be connected to the same [2D] cell unless
    both lateral structures are using the Weir equation.
    Could you give a hint in how to solve this issue?
    Thank you!
    #12017
    Scott Miller
    Either add a computation point, so there is another mesh cell for one of the LS. Or shorten one of the LS a little, so it ends in a different mesh cell.
    #12018
    Yea the most simple way is to click edit>add point> and add a few points between them, This will force the mesh to recompute and should resolve this error
