Welcome to the RAS Solution Forums HEC-RAS Help Two inline structures (dams) connected to a lake, Can RAS run unsteady case ?
  • This topic has 1 reply, 189 voices, and was last updated 11 years ago by Anonymous.
  • #5692
    Hi, there,
    I have two inline structures (dams) connected to a lake, I built both in the ras model. The two corresponding channels downstream of the dams will merge together at a confluence (about 1 mi from the dam). But the unsteady RAS model did not work. Any one has/had similar cases or experiences? Any suggestion or tips will be greatly appreciate.
    Thank you!
    Yee
    #9096
    Yee: That situation should work. Assume that you have the lake being described as a storage area and the inline structures separated from any boundary condtion (the lake and upstream flow inputs) by at least one cross section. I have tested this topology, with each inline instructure being on a different trib., and RAS unsteady runs fine.
