Welcome to the RAS Solution Forums HEC-RAS Help Tweaking X-Sections
  • This topic has 1 reply, 133 voices, and was last updated 11 years ago by Anonymous.
  • #5767
    I have cross sections generated from LIDAR data so they’re missing the bathymetry under the water level.
    I do have the measured flow rate the day the LIDAR was performed.
    Is there a method in HEC RAS to “tweak” the cross-section ? Or, I have to do this manually ?
    Thanks!
    #9245
    Or : Say the flow rate the day the LIDAR was performed was 100 m3/s, should I simply take this flow rate from the design-flow rate ?
