Welcome to the RAS Solution Forums HEC-RAS Help Trouble running unsteady simulation.
  • This topic has 3 replies, 6,839 voices, and was last updated 12 years ago by Anonymous.
  • #5442
    Hello, I am having some trouble running an unsteady simulation, with my model going unstable immediately. Below are my results. any help would be greatly appreciated.
    Geometric Preprocessor Version 4.1.0 Jan 2010
    17 Internal Boundary curve(s) have been read in and will not be recalculated
    Finished Processing Geometry
    Performing Unsteady Flow Simulation Version 4.1.0 Jan 2010
    **** Solution Solver Failed ****
    Minimum error exceeds allowable tolerance at 31DEC2013 2400
    WCW 5 5 399.9997
    WARNING!
    ***** Extrapolated above Cross Section Table at: *****
    EW2 1 from R.S. 999.9999 to 799.9999
    WCW 9 9 R.S. 599.9998
    WCW 11 11 R.S. 277.4888
    WCW 11.1 1 from R.S. 107.0433 to 66.43826
    WCW 12.1 1.2 R.S. 1800
    WCW 12.1 1 R.S. 291.8402
    WCW 12.1 1 R.S. 81.0185
    WCW 13 13 from R.S. 1892.266 to 1522.128
    Finished Unsteady Flow Simulation
    Writing Results to DSS
    Finished Writing Results to DSS
    Reading Data for Post Process
    Simulation went unstable at: 01Jan2014 00:00:00
    No data for post processing
    #8708
    This is my most recent result. Once again, any help would be greatly appreciated.
    WCW 11 11 4600
    #8709
    Keymaster
    Try running a steady flow version of this project. Then look for errors (summary of errors warnings notes) and places where the computed water surface elevation defaults to critical depth. Get it all fixed up nice in steady flow, then retry in unsteady. In unsteady, make sure your initial conditions are good and consistent. For example, if your first time step flow is 100, then your initial conditions flow should also be 100. Make sure your computation time step is appropriate (not too big). And make sure you have enough water in your reach (RAS will crash if it goes dry, or even too close to dry). The steady flow version you run should reveal if this is a problem.
    #8710
    Try minimizing the calculation time. It will take some time but should work.
