I have a 1m resolution DEM, and I would like to combine it with the terrain model of a concrete channel.
I draw XS sections of the channel in HEC-RAS, so I have also the XS interpolated surface provided by RAS Mapper.
Now I create the combined new terrain starting from the base surface (DEM) and the channel surface, giving to the last the higher priority.
Since the base DEM was 1m resolution I kept this cell size also in the new terrain.
However I want to be sure that during the terrain creation operated by RAS Mapper, the original width of the channel is not changed, maybe because the 1 m resolution is too coarse.
In other words, does the XS interpolated surface boundaries will be modified during the new terrain creation? If yes, how can I ensure the channel model to be unchanged after the combination?
I woulf appreciate your help.
Best Regards
